Question about Toshiba Satellite A35-S159 Notebook
My computer screen shrank and I don't know how to restore it to original size. Please help me.
  • 903 Answers
Right click the screen and if using xp go to properties then display and change the resolution back to how you had it, possibly 800 x 600. If using vista right click and go to personalize then display and change the resolution from there.
Hopefully this will help
Posted on Dec 28, 2008
How. Do I take acer touch screen PCs to factory settings
Hi. Most computers have a hidden partition on the hard drive that contains all the factory default settings and system software that originally came with the PC, including the operating system (like Windows 7/8,etc.). There is a simple method to restore your computer to factory default settings using this restore partition. Please be sure to backup any data or files that you want to save on a USB flash drive or backup media first.
I presume that your computer is an Acer Aspire One model touch-screen PC. For this model of computer, in Windows, go to "Start," then "All Programs," then "Acer Empowering Technology."
Then, you want to click on "Acer eRecovery Management."Then, click on "Restore," then lastly, "Restore System To Factory Default." Your computer will then reboot/restart, and launch the Recovery Utility.
When prompted, click "Yes," then "Yes" again to restore/revert your Acer computer to its original factory default state. Please do note that if you deleted the recovery partition from your hard drive by formatting it, you won't be able to use this recovery option. If that is the case, you should be able to use the original system DVD's that came with your computer to restore it to its original factory defaults.
I do hope that I have helped you. Please feel free to ask further questions if you still have need. Thank you.
Oct 26, 2014 | Acer AZ5610U9072 Allinone PC 23' Touch...
Restore software for ipod 16GB touch
i would be checking the usb lead before doing anything or even replacing it with a new one make sure iis securely connected
the cable near the iTunes symbol represents a problem with the cable
and the cd will not not be able to activate without a connection
Connect one end of the USB sync cable to one of your computer's unused USB ports, and connect the other end to the bottom of the iPhone or iPod Touch.
If iTunes does not start on its own, run it using the desktop or Start menu shortcut.
When iTunes starts, you should see an icon for the iPhone or iPod Touch on the left side of the window.
Click "Summary" in the right pane of the window if it is not already active.
Click the "Restore" button to begin the device restoration process.
ITunes displays a message asking if you want to save the contents of the device to your computer before restoring it.
If you have not backed up the device already, click the "Back Up" button.
If you have already done this, click "Don't Back Up."
Click "Restore." ITunes clears the data from your iPhone or iPod Touch and reinstalls the device's original firmware.
The screen of your iPhone or iPod Touch may shut off while iTunes works.
Do not remove the USB sync cable.
When iTunes is done restoring the device, it displays a message letting you know that the device is about to restart.
Click "OK" to restart the device. If you are restoring an iPhone or iPod touch, wait for the "iPhone / iPod touch is activated" message to appear on the screen of the device before you disconnect it from the computer.
You may now restore your backup of the device or remove it from the computer.
hope this helps
Sep 15, 2012 | Apple iPod touch
I want to take my dimention 3000 back to factory settings?
First, if the computer has the restore partition, you should see a blue bar at the top of the screen immediately following completion of POST. After two seconds you should see a message about loading the descriptor for PBR2. If you don't see these things after you start or restart the computer, the restore function is not operational. If you do see them you need to restart the computer, press CTRL and F11 toward the end of POST, and release both keys simultaneously before you see the message about the descriptor for PBR2. If you are successful you will get a screen that has an option to restore the computer to factory configuration.
If you don't see the blue bar, try using Disk Management to see how many partitions you can find. If the partition exists, you should find three. First, a utility partition formatted in FAT-16 about 32 MB in size. Second should be the NTFS partition used for the C drive; this one will be the largest partition on the drive. Third should be a FAT-32 partition of two to three Gigabytes in size. This last is the restore partition. If you wish you can try to fix it, but you will need to study Dan Goodell's page found here: Inside the Dell PC Restore Partition.
If you don't have the restore partition and can't fix it, the only thing you can do is find the CDs that should have been shipped with the computer and restore the system manually. If you don't have the Dell Windows Reinstallation CD, you can ask for one here: Dell Replacement Disks. If you don't live in the U.S. you will need to contact Dell Tech Support for your region and request the CDs.
Hope this helps!
Sep 12, 2011 | Dell Dimension 3000 PC Desktop
I need to restore my computer to the factory settings. I have an HP PavillionDV5000 with Windows XP. When I open PC Recovery and select "PC Recovery", the computer automatically shuts down and...
After you've used your laptop for an extended period of time its hard drive may become filled with files you don't want or even infected with malicious virus programs downloaded from the Internet. If you don't want to go through the folders on your laptop and manually delete each unnecessary file you can restore the computer to its original factory settings instead. Restoring a laptop wipes out any existing data and entirely reinstalls the operating system.
1.Place the operating system recovery CD that came with your computer into the CD or DVD drive. Restart the computer.
2.Wait for the computer manufacturer's logo to pop up on the screen. Press the keyboard key that brings up the recovery menu, which is usually "F2," "F8," or "Ctrl" and "F11" pressed simultaneously.
3.Select the specific language you want the operating system to use from the menu at the top of the screen. Select "Next."
4.Choose the option labeled "PC Restore," "Repair Your Computer" or something similar. Click "Next."
5.Select "Restore" and then click "Enter" to start the process. Click "Restart" once the process has ended to boot the restored computer to its operating system.
Aug 27, 2011 | Computers & Internet
Have ipod 3rd generation 8g, forgot 4 digit screen unlock code an dont know how to get around it? An the original computer that was set up on was destroyed in fire, please tell me that you can help.
Hi r wolfe1975
You can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please take time to rate me
Jul 02, 2011 | Apple Audio Players & Recorders
I was just wondering if u could help me with a problem im having when trying to restore my microsoft windows vista home toshiba sat l505d computer to its factory settings. ive tried to hold down the zero...
Hi pager106, I'm going to try to help you solve this problem. I don't know why you're holding down the "zero key" when you turn your system on, but whatever your reason is, it won't help you to restore the factory settings, so please stop doing it.
SOME (but NOT ALL) Vista and Win7 systems can be restored to factory settings by holding down the F8 key during bootup. Doing this will activate the Windows Recovery Environment, which is a new feature included in Vista / Win7.
Let's do this step-by-step:
1. HOLD DOWN THE F8 KEY, then press the POWER-ON button.
2. After the system completes the POST process, you should see this image on your screen:
http://upload.wikimedia.org/wikipedia/en/4/42/Windows_Vista_System_Recovery.png
3. You will then see a list of FIVE options to help you resolve your computer problems. We will concern ourselves with the THIRD option in the list to help you restore the system to the original factory settings.
NOTE: THIS WILL ONLY WORK IF YOUR SYSTEM ALREADY HAS A FULL BACKUP IMAGE
4. DOUBLE-CLICK the "CompletePC Restore" link, and follow the prompts to return your system to the original factory settings.
NOTE: DOING THIS WILL DESTROY ALL OF THE DATA CURRENTLY STORED ON YOUR SYSTEM. If you have not already saved the data you want, do it BEFORE you run this option.
5. Good luck with this; let us know if you have any problems. If this process does NOT work, it means that your system isn't capable of being restored to factory condition. In that case, you might as well try the "Startup Repair" or "System Restore" options.
More information about the Windows Recovery Environment can be found here:
http://en.wikipedia.org/wiki/Windows_Recovery_Environment
If you have ANY problems, MAKE DETAILED NOTES about the error messages you see, then post them here. With a little luck, we will be able to help you overcome the errors and get your system working again.
Best wishes; please be sure to let us know how this turns out for you.
Jan 11, 2011 | Microsoft Windows XP Professional
I accidentally shrank my web screen and I don't know how to zoom back into normal size. Help
Hi!
To zoom in or zoom out your web screen.. here's what you need to do.
ZOOM IN: Press and hold Control key (CTRL), while holding Control key press plus sign ( + ) to make your screen bigger.
ZOOM OUT: Press and hold Control key (CTRL), while holding control key. .. press minus sign ( - ) to make your screen bigger.
Hope it helps you.
Much appreciated if you rate this help.. thanks
May 19, 2010 | Computers & Internet
My words in my compt. are so small i cant even read my websites well.my kids played wiyh it and they shranked all the words.can u help?
Assuming you have a MS Windows OS. There are a couple of ways to remedy this situation. Option one is to change the screen resolution by right clicking on the desktop screen and selecting Properties and then Settings. Change the Screen Resolution to something lower than the current setting. This will cause everything to enlarge on the screen. Option 2 is to just change the font size as the standard. Right click on the desktop screen and select Properties. Select Appearance and change the Font Size to Large Fonts or Extra Large Fonts. If you are trying to change the font in Internet Explorer then choose View/Text Size, select Larger or Largest. That will change only the fonts inside Internet Explorer.
Nov 12, 2009 | Compaq Computers & Internet
My daughters 2g nano is locked, we dont know the number, how do we unlock it? there is a safe combination dial on the screen which we can`t get past.
Unlocking iPod
You can unlock iPod in one of two ways:
 Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
 Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can’t unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
Important: Apple representatives cannot unlock an iPod if you forget your combination. If you can’t unlock your iPod and you don’t have access to the primary computer, your only option is to restore the iPod, which will erase all music and data.
Nov 08, 2009 | Apple iPod nano
Typeface too big for page
if u have a scroller on mouse click it then scroll this does the size is not right click on main screen and change display size.
actionman
Feb 27, 2009 | Computers & Internet
Toshiba Satellite A35-S159 Notebook Logo
431 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
