Question about Epson Stylus Photo 1270 InkJet Printer
PDF file I'm trying to print a PDF file but when I click print and the Stylus 1270 window appears I get the octagonal exclamation point and it won't print. Why?
  • 12 Answers
SOURCE: Vista driver for Epson Stylus Photo 1270
There are no Vista drivers for this printer.
Posted on Aug 15, 2009
0 characters
1 Points
Printer prints PDF but pulls page back in a few inches
Try this: Go to print a pdf file by clicking file/print. When the print properties box appears, click on the Advanced button on the bottom. Check the Print as Image box and click OK, then print your pdf file. If it still does not work, update, or delete and reinstall your print driver.
Aug 11, 2012 | Kodak ESP C315 Wireless All-in-One Printer
Hp officejet pro won't print pdf files
In order to print PDF file format grab CutePDF.
  • Visit . Click "Free Download." A box will appear asking, "Do you want to run or save this file?" Answer with "Save." The download will begin. Download Ghostscript (see link in Resources). Look for "You Can Get the Free GPL Ghostscript 8.15 Here" sentence and click "Here." This download is required for the CutePDF program. Save the GPL Ghostscript file to your desktop.
  • Double click the "CuteWriter" icon on your desktop once your downloads are complete. Click "Next" on the Setup - CutePDF Writer screen. Click "I Accept the Agreement" on the License Agreement screen. Click "Install." The CutePDF setup will run. Click "No" to the CutePDF Writer Setup box that appears next that asks "Would You Like to Download the Converter?" You have already downloaded the converter. Once the setup is complete, a Readme.htm file will appear in your Internet browser. Read this file or print it.
  • Double click the "Converter" icon on your desktop (it will have a black "G" as its icon). Click "Setup" on the right side of the WinZip Self-Extractor converter.exe box. Another box will appear and then disappear. The setup is complete, and CutePDF is ready for use. CutePDF installs itself as a printer, and this allows any Windows program to create a PDF.
  • Open any Windows application like Microsoft Word or Excel. Open any document you would like to convert to a PDF file.
  • Click File > Print. Select "CutePDF Writer" from the Name List in the printer box. Click "Properties." Choose your "Layout" and decided how you want your page to print. Click "Paper / Quality" and "Color."
  • Click Advanced > Page Size. Click "Print Quality" and change the DPI. The bigger the DPI, the larger the file size of the PDF will be. If you are creating a PDF to be emailed, choose 72 DPI or 144 DPI. If you are printing this PDF, choose 300 or 600 DPI. If sending the file to a commercial printer, choose 600 or 1,200 DPI. For most applications, just adjust the DPI setting and leave the other settings alone.
  • Click OK > OK > OK. A "Save As" box will appear. Enter a filename for your PDF file and select the directory you would like to save the file to. Click "Save." Your PDF is done.
  • Oct 27, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
    I replaced my ink cartriges and I'm still have a blurr and fade on documents that I print.
    1. Open your application program.
    2. Select Print from the File menu. A Print window appears.
    3. Make sure EPSON Stylus CX9400Fax Series is selected.
    4. Click the Preferences or Properties button. (If you see a Setup, Printer, or Options button, click it. Then click Preferences or Properties on the next screen.)
      A printer properties or preferences window appears.
    5. Select the type of document you're printing for the Quality Option setting.
    6. If you want to print borderless photos, click the Borderless checkbox.
    7. Make sure you've selected the paper type and size you're using for the Type and Size settings in the Paper Options section.
    8. Click the Advanced button. The Basic settings change to the Advanced settings.
    9. Make sure the High Speed option is not selected in the Print Options section.
    10. Make sure the Black Ink Only option is not selected in the Print Options section if you're printing a color or black and white photograph.
    11. Select ICM in the Color Management section if you're trying to precisely match on-screen colors.
    Jan 18, 2010 | Epson Stylus CX9400 Photo Printer
    I cannot get a high quality print from my Epson 1270 out of any of my Adobe software. I'm on a MAC OS X 10.4.11. thanks! Help I'm on deadline with a job Kris
    There could be some color profiles associated with your Adobe software that are not in your printers' color management. If you can save your file in jpg format and print it as an ordinary picture you might get the result that you wanted. Good luck!
    Jan 15, 2010 | Epson Stylus Photo 1270 InkJet Printer
    Horizontal lines (red) on first 1 - 2 pages of initial print-out
    Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
    Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
    Printer keeps showing a stop job with exclamation point
    Do you have a Mac OS X?
    Maybe you just need to reinstall the driver. Download it through the following link:
    Let me know if it does not work and tell me what OS version you are using. Click on the Apple menu and select About This Mac to get the version.
    Apr 15, 2009 | HP OfficeJet G55 All-In-One InkJet Printer
    Paper feeding
    I beleive it is the paper thickness lever on the right side when you lift up the scanner section.
    Here is the setup guide:
    Please remember to rate Techs who assist you for free :)
    Sep 12, 2008 | Epson Stylus CX6600 All-In-One InkJet...
    Poor printing Epson Stylus Photo 1270
    please change the colour cartridge it may be slightly dry
    Sep 18, 2007 | Epson Stylus Photo 1270 InkJet Printer
    Epson Stylus Photo 1270 InkJet Printer Logo
    15 people viewed this question
    Top Epson Printers & Copiers Experts
    Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
