Question about Jensen MP7610 CD Player
Cd player wont read most cds
My mp7610 cd player won't read most cds recently, when it does it sounds like its playing at a high rate of speed for 2 seconds then tries to load once again. Any help? or should I just replace the unit?
    Scholar:
  • 105 Answers
Try a lens cleaner first . If that doesn't work then i would send it in for repair or purchase a new unit .
Posted on May 18, 2009
Won't play CDs
IF its CD YOU BURNED YOURSELF THE PLAYER MAY NOT SUPPORT BURNT DISKS (the process is different than commercial disks in manufacture. This is usually a problem with older cd players. The disk may have errors, never burn at high speed, for example in nero, go to options and change burn speed to 8x. rewritable disks are always a problem, use cd-r
Feb 07, 2016 | Audio Players & Recorders
Cd wont play
If the player do switch ON, and it won't read CDs, the fault might be to its optical pickup unit. Seek tech support.
Jun 01, 2012 | Kenwood CD-423M 200-Disc CD Player
Rcd159a boom box PLL digital radio- plays all the old mp3 cd's with a write speed 16x & under but any newly burnt one with the high speed disks fail
That's not unusual. Slower burning speed results in a deeper burn which is easier for some players to read. Unlike commercial discs which are highly reflective, burned CDs don't bounce as much light back to the laser in the pickup. Too fast a writing speed when burning can make some discs unreadable. This is why some older players can't read burned CDs at all; they were never sensitive enough to begin with. It's always a good idea to keep the write speed low (16x or so) when making CDs that will be played back in a regular CD player or boom box.
This problem is more likely to occur as the CD pickup ages and the laser weakens. If higher-speed burned discs used to play and now are having problems, it's probably time to replace the boombox (or the pickup assembly if you're ambitious). If the higher-speed discs never played, the player just can't deal with them and you'll need to keep the write speed down when burning CDs.
Nov 21, 2010 | Audio Players & Recorders
Copied CDs won't play with my Aiwa LCX 350 shelf system. It will spin for a bit, then stop. I've tried every method ... with or without remote, start/stop, etc. This doesn't happen with any retail CD. Only...
It sounds like it's not reading the CD. 2 things to try, neither of which are guaranteed to work:
1) Try changing the brand/colour of your recordable CD.  Some machines read different colours/brands better than others; particularly older CD players.  If the ones you have are all light-coloured, try burning a couple of dark-coloured CDs and see if that helps
OR:
2) It could be the speed at which you're recording.  Try burning a CD at 1x speed and see if that helps.
May 26, 2010 | Aiwa Audio Players & Recorders
Jensen 2006 7" indash touch screen: CD player wont work
Try a lens cleaner . If that doesn't work then it would have to be repaired.
May 07, 2009 | Jensen MP7610 CD Player
Dosent play burnt cds
Try to burn cd in 4x speed burn. Or try to burn the audio as CDDA format at lower speed burn.
Crackes usually appears when burn the cd at high speed.
Pls. leave a comment
Apr 10, 2009 | JVC KD-SX770 CD Player
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
Axis 8
try cleaning the lense using a lense cleaner and/or burn your cds at slower speeds. 16x and lower work best
Feb 08, 2008 | Nu Mark AXIS 9
How do I copy a CD on my denon CDR-W1500
Operating instructios can be downloade here:
http://www.retrevo.com/s/Denon-CDR-W1500-CD-Players-review-manual/id/363ci860/t/1-2/
10 COPYING PROCEDURE
About copying
 Copying can be performed easily from the set’s CD unit onto the CD-R unit.
 There are two copying speeds (normal and high) and four copying modes.
• The mode switches as described below each time the normal speed copying button (NORMAL) or the high speed copying
button (HIGH) is pressed.
• The recording level is automatically set to the default value (0.0 dB).
• The repeat and random play modes are canceled when the copy mode is set.
• During normal speed copying you can listen to the sound as you copy.
• During high speed copying no sound is produced.
• No signals are output from the digital outputs during high speed copying.
• During copying, buttons other than the CD or CD-R stop buttons do not function.
• When CD TEXT compatible CDs are copied, the disc names and track names are also copied.
 When copying, switch the relay mode to the normal or dual mode. Copying is not possible in the relay or mix mode.
 For optimum recording, make sure there are no fingerprints, scratches or dust on the signal surface of the source side CD or
the CD-R/RW.
 The auto track function is always activated in the copying mode. It is not possible to assign track numbers manually.
Disc dubbing: In this mode, entire CDs can be copied onto CD-R/RW.
(“All Tr Dubb” is displayed.)
Make CD: In this mode, entire CDs can be copied onto CD-R/RW then finalized automatically.
(“Make CD Dubb” is displayed.)
1TR dubbing: In this mode, single tracks on CDs can be copied.
(“1Tr Dubbing” is displayed.)
Scan REC dubbing: In this mode, the desired tracks can be selected from CDs and copied.
(“Scan Rec Dub” is displayed.)
Jan 14, 2008 | Audio Players & Recorders
Trouble playing store bought cd's
itll be the lens on the player clean it with surgical spirit
Jun 26, 2017 | Lenoxx Electronics CD-102 Cassette/CD...
Jensen MP7610 CD Player Logo
129 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
