Question about Engel Freezer 22 Qt. Fridge/Freezer
Motor goes on/off every few second.
When I turn on my Engel 40ltr car fridge the motor starts and runs for about 5-10 seconds. Then it sounds like it gets an increased load, (motor sound becomes louder & deeper. Then it stops altogether. After a few seconds it starts the same cycle again - ad infinatum.
Ron V
  • 3,463 Answers
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Posted on Dec 29, 2008
On the circuit board for the swing control you will find a switching transistor which has an overheat cut off attached - it may be that the switching transistor is overheating or the temp monitor is U/S - you can check this by doing a short run with the overheat cut off bypassed. The switching transistor uses the curcuit board box as a heatsink - If in doubt it may be worth changing both.
Posted on Mar 31, 2012
We have a Bosh KIM29473GB for some time water has been collecting in the bottom tray of the fridge and only takes a few days to fill up, this weekend the freezer stopped working and now nothing works.
If you hear a click every few minutes and a buzz / click then nothing, it would sound as if your compressor is gone, the water problem is the defrost drain pipe is blocked
Oct 06, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Arb - Engel 40ltr not working with dc cord
when you crushed the cord you mite have shorted something else out so you mite have to call a technician out .
Feb 18, 2013 | Engel 40 Qt. Portable Fridge / Freezer
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Long running periods with Engel B 12v fridge
the owners manual will tell you but yes most do
Apr 11, 2010 | Engel Freezer MT 27F-U1
My cpca 291 fxk problem is freezer frosting up and struggles to freeze things and fridge is not cold enough
sounds like your fan motor has seized or burnt out a winding,, this will need replacing. check by holding lid open to raise temp but at the same time hold down the button that the lid presses on when its shut, after about 10min the fan should run.
Nov 10, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
The motor in my freezer makes a very loud noise and sounds like it is trying to start, it takes a few seconds before it stops the noise, then starts running the freezer.
That's usually mounts inside the compressor. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Oct 27, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
It's not too difficult to remove the ice maker. A few screws and the unit will unplug from the fridge. Then you can see why the bar is not turning it off. If it's really broken, check for parts or a replacement unit. Meanwhile the fridge can keep on working, and you can use trays to make ice.
May 03, 2009 | Jenn-Air Freezers
Indesit fridge Freezer
I think you'll find the relay is there to start the pump by switching the mains to the shorter winding in the motor, hence three terminals. Once the pump is running the relay "drops out" and the motor runs on the longer winding. Check with a multimeter if the windings are intact. There's no Positive and Negative for AC operated devices i.e. it doesn't matter which way around the power (live and neutral or Hot and Cold) goes in but Earth or Ground MUST be correct. Dont kill yourself!!
Sep 26, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Engel Freezer 22 Qt. Fridge/Freezer Logo
426 people viewed this question
Top Engel Freezers Experts
John Tripp
John Tripp
Starnley Johnwells
Starnley Johnwells
Victor Nwachukwu
Victor Nwachukwu
Are you an Engel Freezer Expert? Answer questions, earn points and help others
