I left and set my fresh air by ecoquest on away mode. When I got back a few hours later the machine would not turn back on. Please let me know what I can do to fix this problem.
There could be a couple issues at play here. 1) The power cable might not be plugged in correctly. 2) The fuse might be blown 3) there might be another electronic failure.
1 and 2 are pretty easy to check. Go to www.healthylivingia.com and look for the FreshAir, under the support tab you will find manuals that you can print out. For the third option you would have to send it in. An authorized repair center needs to take a look at the machine and diagnose the problem. You can call EcoQuest at 1-800-989-2299 to find out where the closest repair center is.
I hope this helps. Eric
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Fresh Air Living Air
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several...
(More)
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several times but the unit always comes bak on and tell me it need normal cleaning . I cannot clear the display. I have just given the unit a thorough cleaning but the display still say perform cleaning. Nothing on the front control responds.
Ecoquest Fresh Air was left in a car running for two hrs with heater on, when we returned machine...
(More)
Ecoquest Fresh Air was left in a car running for two hrs with heater on, when we returned machine was not working.
I have two identical units and I have swapped every removeable/replaceable part including cord and...
(More)
I have two identical units and I have swapped every removeable/replaceable part including cord and new fuse and the unit will not power up
I replaced the purifier plate, but the purifier will only briefly come on for 1-3 seconds then it...
(More)
I replaced the purifier plate, but the purifier will only briefly come on for 1-3 seconds then it goes off. Do you have a solution to this problem?
