Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
My router is not sending out a wireless signal
  • snwboarder91 Feb 17, 2009
    wireless signal not being sent. worked for a week then stop for no reason, dont know how to fix the problem. help!!
Hold down the center blue flahing lights. They will come on solid, then turn off. Next press again (quickly) and all sshould work.
Posted on May 03, 2009
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: router randomly stops sending out wireless signal
You may be getting interference from other routers in your area.
Check to see what channels the other routers are broadcasting in your area, change it to a channel that is not being used.
The location of the router could affect the signal strength, move the router away from concrete reinforced walls etc, and or move the router to a higher position in a clear space.
Posted on May 22, 2009
  • 4044 Answers
SOURCE: Hello, I have Edimax br-6204wlg router
You will need to connect to the router with a cable and access the router configuration and setup. Make sure it is set to broadcast SSID and that it is not using WEP or that you have the same WEP key and Network SSID configured in the laptop. Next you need to check that the channel it is using to broadcast SSID information is not channel 6 if you have an HP laptop. Change that to channel 10. Of course the first thing you need to double check is that your wirelss on the laptop is turned on and capable of connecting to the router. If the router is using 802.11B and your laptop is only capable of using 802.11G they will never see each other.
Posted on Oct 30, 2009
Testimonial: "Thank you very much!!! I will try, right now!"
router-user
  • 550 Answers
SOURCE: my router isn't sending a wireless signal.
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Jul 21, 2010
mind397
  • 16 Answers
SOURCE: hi there, i got a
Sure, I can help. First off I need to know more information. Are you planning on connecting the printer, through USB, to your laptop then sharing the printer from there to other computers? If so, it is a matter of adding that printer, going into the printer properties, sharing tab, and sharing the printer. Or are you trying to share your printer wirelessly? If so you may need to buy a wireless print server. It acts as a base to share that printer and then allow you to wirelessly find it and connect. If the above doesn't help please tell me the make and model of your printer, laptop, and wireless router.
Best, -Mind
Posted on Aug 03, 2011
My router isnt sending signal to my printer
The router doesn't send signals to a printer. The Linksys transmits a radio signal recieved by the wireless adapters on other devices, if your printer has wireless compatibility it must be setup on the printer, in the wireless settings. I don't think it's a Linksys issue. It a computer software issue. If you post the Computer Make, Model, and your OS, the Printer Make, mode,l I will try to help you. Is this the first time using the Printer?
Jan 11, 2013 | Linksys Wireless-G WRT54G Router
Tip
How to improve signal strength on a wireless network
The success of a wireless network depends on the signal strength. A strong signal is required so all networking devices can communicate with each other. A weak signal causes low bandwidth preventing communication between hosts and causing network disruption. <br /> <ol> <li>Pay attention to router placement. It should be away from walls, floor, and glass and metal objects, all of which disturb wireless signals. If possible, place the router in a central location.</li> <li>Change your router's standard antenna to use a high-gain antenna that sends signals in one direction. This way signals can be focused in the required direction. Standard antennae send signals in all the directions, which may not be desirable especially if the router needs to be placed next to a wall.</li> <li>Use a wireless repeater, the device that enhances range of a wireless network.</li> <li>Change the channel on which the router is functioning. Similar to radio stations, routers function on different channels one of which may give better performance than the other.</li> <li>Ensure the network card installed in the hosts is capable of receiving and sending signals to the router. In this respect, using equipment from one manufacturer is better.</li> <li>Check the vendor's site regularly for latest updates, performance enhancing tips and fixes.</li></ol> if you need more information regarding improvement of wireless network, visit<a href="http://www.microsoft.com/athome/setup/wirelesstips.aspx"> THIS</a> site.
on Dec 13, 2010 | Computers & Internet
My d-link dir-651 does not have a good signal
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Aug 27, 2012 | D-Link Computers & Internet
If the wireless light is not ON,does that indicate that this router is not sending a wireless signal? and if so how this can be resolved?
Yes, it means that the router is not sending a wireless signal.. You will have to follow the instructions in the manual that came with your router to enable wireless transmission.
Regards,
Yavacotech
Jan 24, 2011 | 2wire Computers & Internet
My router is not sending a wireless signal but my internet is on
Unless you have a meter that detects wireless signals, you cannot be sure that your router is not sending out a signal. If you access the configuration utility for the router using your web browser and the gateway IP address, you can nose around inside of the router and determine if wireless is on or off. If you see the SSID on your computer and it will not connect then it is most likely a problem with your computers' configuration. If you don't see the SSID it is either checked to not broadcast, wireless is turned off, or you router is defective.
Jan 22, 2011 | NetGear WGR614 Wireless Router
My wireless light on my router keeps blinking, it will not send out a wireless signal either... I can connect wired throught the desktop but that is all
Try to check the configuration setting of your wireless router. There must be a problem in one of its configuration settings causes it not to send out wireless signals.
Nov 02, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My router isn't sending a wireless signal. just setup internet with comcast and now the router isnt sending ethernet wireless
Jul 21, 2010 | Linksys Wireless-G Broadband Router
Wont send signal
Please check your router's setting area and must be your router on mixed mode.
Apr 13, 2010 | Linksys Wireless-G Broadband Router
The router is not sending out a signal for my laptop to pick up. What are some possible soultions for this issue?
If you can access the router setup page, change the wireless channel to a higher value and save the settings and then check if the router will be sending the signal fine now but if still not reset the router by pressing the reset button for 10 seconds while power is ON and then check if the signal is showing now...
Dec 16, 2009 | NetGear WGR614 Wireless Router
Router randomly stops sending out wireless signal
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
223 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
