Question about Car Audio & Video
Sub making noise
I have a 15 inch mtx thunder 7000 sub that I have never really used, when i pulled it out of storage and hooked it to an amp, a sound was coming from the dust cap that sounded like something was hitting it, upon placing my finger on the dust cap, the noise ceased. the movement of the cone seems intact, does this mean the speaker is blown?
  • cedwards665 Dec 30, 2008
    Thank you for your response, I tried shaking it but heard no noise, I tested the speaker with a ohm meter and it read 1 ohm, does this mean that it is not blown? I am going to do some surgery on the dustcap to see if something is loose behind it. When I hooked it to an amp that I have on 2 12" subs, the speaker seemed to play fine if you hold the dustcap, although the output is very weak. Thank you for giving me some direction as to how to check this out,,,, I am glad there are smart people like you in the world
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
As dumb as it sounds, shake the speaker up and down with the speaker facing down. If the sound is there, there is possibly something inside the voicecoil that has come loose over time. If aetheitcs is important, stop here. The dust cover just keeps the voice coil from rusting. Use a box knife and cut a ****. Push one side of **** slightly inward. Prop it apart if you can. Shake till whatever is in falls out. A touch of silicone across cut will reseal.
Posted on Dec 28, 2008
  • bob collins
    bob collins Dec 31, 2008
    1 ohm doesn't mean the speaker is blown because that isn't how it works. That being said, the reason it sounds weak is probably because it isn't mounted and is required to be to sound good.
I just bought 2 12 inch mtx thunder tc512 to replace my old school mtx blue thunders, everything worked great, but when i hooked up the new 12s i get nothing, zero, zip, nadda, there is nothing wrong
use a d cell battery and touch + of speaker to + of battery and hold it by doin the same with the -'s too if move they work if not there junk
Sep 09, 2012 | MTX Car Audio & Video
How big of hole do i need for the mtx 6000 thunder 10in
The MTX Thunder 6000 T61544A is a 15" Subwoofer meaning you will need a 15" hole to fit the subwoofer into. The mounting plate that surrounds the subwoofer will extend past 15" allowing you to screw the sub in properly. Be sure to use a box that is at least 12 inches deep (sub is 10 inches deep by specifications + 2 inches for good air cushion behind.
Mar 01, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
MTX 12'' sub noise
Sounds like your sub is overextending itself, and possibly losing contact at the voice coil. Overextending will make a weird rattling sound, losing contact at the voice coil will make a popping sound.
Jan 12, 2010 | Car Audio & Video
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
Fuses
Check the ohm measurement of the speakers make sure they are about the rated ohms.Check them UNHOOKED from the amp. (Useually 4 ohms.)
Try different subs.
May 25, 2008 | MTX Thunder 3401 Car Audio Amplifier
Mtx 895 trouble
check your fuse up front first. some amps will turn the light on with only the remote wire (the 12 volt signal from the head unit). That may be your issue. If not you need to check your signal input. try hooking the rca's to a diffrent source, i.e. other radio your tv anything with Rca out put. If still you get nothing then pull your subs out and take a regular 9 volt battery and touch the leads to the positive and negative of the sub. Just for a moment though if the subs move when they come in contact with the charge from the battery then my last suggestion would be to take it to a store where you can have an authorized tech check out the equiptment. Good luck
Nov 19, 2007 | MTX Thunder 895 Car Audio Amplifier
Car Audio & Video Logo
163 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
