Question about HP Compaq Presario V6000T Notebook
My laptop screen flickers on then shuts off when i turn on my laptop. The power button is still on and i put in a cd it ran it, but i couldnt see what was happening. The people at a store told me it was the circuit board, but i dont want to pay that much to get it fixed, i think its just the fl inverter
  • Brian Canute May 11, 2010
    possibly loose cable the invertor will light the screen not display if your screen is still bright try cable if not send model number for your invertor and will locate price for you
Screen cannot be unlocked usink keypad and screen unresponsive after turning on screen with power button ,
they say if you tap the pad twice firmly in the upper left hand corner this will unlock the pad! some hp's has a light button on keypad, you tap the lighted button twice firmly just as you do with out lighted button
Apr 03, 2016 | HP Computers & Internet
When the laptop is turned on, the screen rolls & flickers. I can press on the sides & it stops.
Hello collensdrea,
Welcome to!
Sorry to hear what's happening to your laptop. I would lke to ask you to follow a few steps to check and see if this is a faulty display or not. Please follow the following steps:
1. Turn the laptop off 2. Unplug the AC adapter (if connected) and remove the battery 3. Press & hold the power button for 40 seconds w/o the battery installed or the AC adapter plugged in 4. Let go of the power button, reconnect the AC adapter and put the battery aside for the meantime 5. Turn the laptop on by pressing the power button and the second you turn the laptop on, tap F2 several times to load the laptop's BIOS.
What is a BIOS? This is a special screen that let's you make changes to your laptop's motherboard. Please do not wander around as it may cause the more problems if you are not sure of what you are doing.
The reason why we went here is to see if we can still recreate the same issue i.e. the screen rolls & flickers.
If it still rolls & flickers, I'm afraid you need to contact Acer to have your computer sent to Depot or serviced.
Aug 22, 2011 | Acer Extensa 4620-6402 Notebook
I have an Acer Aspire 7520, i was on it today and all of a sudden the screen froze. I couldnt do anything, couldnt click on anything, shut it down, i had to pull the battery and plug. then when i went to...
Do you get the posting beep??
Sounds like faulty ram.
Remove battery / depress on button several X to de-energise system.
Remove ram / reseat / reboot.
Apr 13, 2010 | Acer Aspire 7520-5185 Laptop
Sounds like a failing hard drive.
Have you got an XP or Vista cd around?
Feb 25, 2009 | HP Pavilion TX2510US Notebook
Blank screen when powered on.
Do you have any CD’s that came with your laptop? If so, look for one that has “Diagnostics and utilities” listed under the “Contents”. To boot from that CD disk, power on your laptop and tap the <F12> key to bring you to the “One time boot menu”. Insert the CD and then select CD/DVD drive and hit <Enter> key. You can also boot from the Windows reinstallation disk. If the computer boots from either CD, then your Operating System is corrupted and needs to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 22, 2008 | Dell Inspiron E1505 Notebook
IBM ThinkPad T30 starts up, then turns off
Motherboard is damaged I recommend ebay for a board of that type, there is no simple fix I own three T20s and when one did the same thing I just replaced the motherboard that solved the problem. the lcd screen and inverter were fine.
based on the non powering issue now I would say the MB is shot, replacement will give you a few more year use however for a reasonable price.
Apr 29, 2008 | IBM ThinkPad T30 2366 Notebook
Sudden shutdown / will not power up
try check your BIOS.Upon turning ON your laptop, press down the DEL button of your keyboard then check settings of your maybe activated the standby mode by certain time.
Jan 17, 2008 | HP Pavilion ze2000 Notebook
HP Compaq Presario V6000T Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
