Question about Hitachi 53SBX59B 53" Rear Projection Television
Hitachi 53SBX59b Rear projection TV out of convergence
I have a Hitachi 53SBX59b Rear projection TV that is approximately 6 years old. When I bought it I noticed that the upper left hand corner of the screen was a little out of convergence. I had a repairman check it and he said it was fine. Now a few years later it is much worse. I have heard that there is a way to manually adjust the convergence without calling the repairman. This TV has magic focus which works ok, but never gets the bad area in focus. Does anyone have any idea how this is done. Thanks
  • moderin Jan 25, 2009
    what can you do to fix the problem ourselves?
    Genius:
  • 1,074 Answers
From you bought the tv and notice that it has that stain on the edge you should have taken it back as it was covered under warranty.now it is getting worse it will cost you to get it fix your tv has a factory defect.you will have to call the repair man to fix your tv.good luck.
Posted on Apr 26, 2007
Won't magic focus
Magic FOCUS button no help all?The tv have a problems known as a convergence problems,it dead 100%.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors it dead too.These parts on the tv convergence board must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Dec 08, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Hi I currently own a Hitachi rear projection . And I was trying to tune he color and I think I burned the tube I have a line onbrhe screen. Is there a way to clean the picture tube or replace it
Tv colors lines R,G.B mis alignment,colors shadows pictures or 3D pictures?Yes,this tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence board problems.Will solved the picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Red and green outkines figuires and blue lamp is out
Convergence is dead,must know how to solders.Buy a convergence kit,replaced what in that kit.Tries Tv repair World.com,Tvrepairkits.com.
Jan 12, 2010 | Hitachi 53SBX59B 53" Rear Projection...
My 6 year old 65xwx20b tv convergence problem
Good Day,
This is a common problem with this TV, but there is an upgrade to correct the CONVERVGENCE circuit problem.
If you want to repair this concern yourself: Contact: B&D ENTERPRISES,
1-800-458-6053, www.bdent.com and ask for KIT10 for your Hitachi TV.
If you want some else to do the repair for you call an Authorized Service Center.
Needs convergence IC's
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Good Luck,BIG IRISH.
Nov 23, 2009 | Hitachi Director's Series 65XWX20B 65"...
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Digital Compatibility
TVs, VCRs, DVD players, camcorders and video games will continue to work, even if they are only analog-capable. Such equipment, however, may not provide digital-quality picture and sound.
Hope this helps.
Feb 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
How do I Remove Front Cover Screen of Hitachi 53SBX59B53 Projection TV???
Did you ever find the solution to removing the front screen? I have the same problem. Please write at superduper200554@yahoo.com
May 05, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53SBX59B 53" Rear Projection Television Logo
215 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
