Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Will not spin water out -
The machine will wash - but when comes to spin out water it will not work. tried other areas on the machine - and still not draining water out or spinning....
  • beth
    beth Dec 28, 2008
    that was not the problem, any other solution to try?
    Problem Solver:
  • 7 Answers
Sounds like a bad lid switch or timer
Posted on Dec 28, 2008
  • 640 Answers
Check your lid switch
  • onthethejob1
    onthethejob1 Dec 28, 2008
    check for kinked hose..blocked drain pipe..,,,test take all the water out unit bail...see if unit spins but the pressure switch must be satisfied,,meaning no water in tub,,if you put hose down lower than the machine the water will run into a bucket just drop drain hose low...let me know what happen
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
SOURCE: washing machine not spinning or draining water
I have the same washer, WT-R801. Does the machine stop all together when the spin cycle arrives?, if so check the pump on the drain. Mine was burnt out. Its available for $61.00 delivered from Adelaide. Steve.
Posted on Mar 31, 2008
docjohn174
  • 943 Answers
SOURCE: fridgidaire model fwx223lbs4 will wash, but won't spin fast and the water won't drain
HI thanks for the question it sounds like the pump is either burnt out or jammed with debris thanks the appliance doc
Posted on Sep 13, 2008
jsrock516
  • 5911 Answers
SOURCE: Full of water will not drain or spin
I don't know which switch lever you're talking about, but this is a common symptom of a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike (if equipped). NOTE: Some washers have a lid switch that is located under the washer rim near the left or right lid hinge. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms. If your washer has the other type of lid switch that I described, you can sometimes adjust the hinge rod that activates it by bending it slightly.
You can find replacement parts at searspartsdirect.com. Just type in the model number and you can usually locate what you need under the "Top and Cabinet" heading. The part number for the lid switch on the washer model you have this listed under is 3949247. It is listed as item number 11 and costs about $35. The lid strike will be listed as part number 358684 which is item number 20. It costs about $5. So, if both parts are required, you're looking at about $40 in repair costs if you do it yourself. A rather inexpensive fix, for what may appear to be a big problem.
I hope you find this information helpful. If you still have questions, please post back so I will be able to assist you further.
Posted on Sep 24, 2008
  • 133 Answers
SOURCE: water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Posted on Oct 12, 2009
Hi my MW512 Fisher Paykel doesn't spin properly washing still comes out with water still on
could be something stopping the pump from working,, the water control is leaking allowing water to come in while spinning, outlet hose from pump blocked/kinked
and not reaching full spinning speed ( overloaded wash)
May 06, 2016 | Fisher Washing Machines
I have a lg front load washing machine model
There is most likely a blockage prenting all the water from draining out by the time the spin cycle starts. check drain hose and filter if there is one.
Oct 03, 2014 | Washing Machines
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
I have a new Danby washing machine but leaks from the springs area and several other areas. Will not fill with water and no wash cycle will engage. Seems to drain...spins well...but has an "intermittent...
you have a new washer so why not get the service agents out under warranty to fix the faulty machine
ask why there was water in a new machine as that indicates not new but second hand
May 25, 2017 | Danby DWM99W Top Load Washer
Leaking
Sheets Or Comforters? This Normally Occurs With An Overload Such As Pillows And Comforters Due To The Large Circumference. Which Simply Means That Anything That Has A Large Area Will Make The Water Come Over The Top Because When The Machine Is Running The Spin Cycle The Large Area Of Fabric Covers The Side Of The Machine. Actually Causing Water To Spin Off The Top Of The Fabric And Over The Sides Of The Washing Machine Bucket Thus Ending Up On The Floor Below.
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Agitate
does the unit Spin?? or just pump out the water ??? i am trying to see if you need a $10 part or a $150 part plz post
Jan 21, 2008 | Whirlpool LSB6300PW Top Load Washer
Washing machine - not spinning, loud buzz
Sounds like your machine is not receiving any water. It could be that your tap (fawcet) is turned off, or there's a kink in the hose.
Nov 26, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
