Question about Sony VAIO NV170P Notebook
WinXP can't start.
Sony VAIO NV170 system recovered month ago by OEM recover- cd (Winxp home), worked ok, but this morning when turned on the pc, the screen displyed the flash program-loading bios rom image file by phoenixphlash utility 4.00, after the flash programing complete the pc turned off, if turn-on the pc again will repeat the same process, it can't open the window. What's the problem? needs help! Thanks. YLee
  • Leigh Lee Apr 27, 2007
    Hi Sandrew, thanks for your
    I had check in the cmos setting, the time and date is corrected, all of settings looks ok, but the problem isn't ok, where the cmos battery is located on the pc bottom? do I need remove the big battery also? what's the reasons caused this problem, it's virus or parts faulty? before this problem I see some more noise from pc when click mouse,and when I turn-off the pc some message on the screen but I didn't see it what it said.
    President:
  • 2,961 Answers
It maybe that the bios chip is faulty or stuck in a loop as what it seems to be doing is trying to run the bios flash programme. Next time the pc boots up press F2 or Del and in the cmos settings see if the time and date is correct, if not correct it and look in all the menus for something similair to bios flash utility updates and dissable it if enabled or select off, save settings and exit for a reboot. Hopefully it will stop, that's if you can get into the bios without this programme flashing up. If you cannot stop it you will need to reset the bios and the only way may be to remove the bottom compartments of the laptop and look on the motherboard for the cmos flat round shaped battery and remove it for 10 minutes or so and then replace and try again, or only other option is to speak to sony technical as a bios problem is a serious one and cannot sometimes be resolved other than a motherboard replacement i'm afraid.
Posted on Apr 26, 2007
  • andrew pester
    andrew pester Apr 27, 2007
    You are always wise to remove the charging battery, but the cmos battery is only a small round battery part No. CR2032 3V.
    Can't say what the original cause would be, i doubt it was a bios virus, you have to be really unlucky, it is probably a motherboard bios fault.
My sony vaio vgn-cr220E was uprraded from vista to windows 7..why does the biult in motion eye camera doesnt work..
You need the Win7 camera driver, check sony support at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNCR220E&SelectOS=44
just enter your Win7 operating system (there are 9 versions of Win7), and select the downloads (2)
for your computer camera driver.
Versions of microsoft Win7 - determine which yours is by (these instructions are for WinXP);
START > Control Panel > System > General (tab)
Windows 7 Home Basic 32-bit
Windows 7 Home Basic 64-bit
Windows 7 Home Premium 32-bit
Windows 7 Home Premium 64-bit
Windows 7 Professional 32-bit
Windows 7 Professional 64-bit
Windows 7 Starter 32-bit
Windows 7 Ultimate 32-bit
Windows 7 Ultimate 64-bit
May 14, 2011 | Sony VAIO VGN-CR220E/P Notebook
I have a Sony Vaio VGN-N130G. It fell & ever since I get a BSOD saying unmountable boot volume. I've tried to do a Vaio Recovery but now got an error code of 400 which has to do with RAM. Is there any...
If you do a full sys restore, it will wipe out all old data..
What you need to do is boot up on a CD first and try to repair the MBR (Master Boot Record)
Look here - 4th one down.. to download a Boot /repair CD image to burnto a CD
http://www.answersthatwork.com/Downright_pages/Boot_CD_and_Boot_Disk_images_and_ISO_free_downloads.htm
Read all instructions with it.
OR need to find someone who can loan you the WinXP CD . Or a copy of it. (Or download an ISO (burnable copy) to create one) It is the serial number that validates the Windows install. They don't have to give you the serial as you should have your own on a label under the notebook.
Actually the chances are not good for recovery while in the notebook. You will have a better chance to recover files if you are able to remove the hard drive and install it aas a slave in another (desktop) PC (will come up as D or E drive
When you've finished recovering file, it will be easier to format the HD before putting it back in note book. If the Recovery partion is still intact, do not wipe it out as you can maybe still use it to reload windows.
Worst case - the HD read write heads are damaged and the drive is toast. That will mean no file recovered and replacing HD with new (or used) and reloading windows from scratch.
Dec 27, 2010 | Sony VAIO VGN-N130G/W Notebook
Vaio computer PC wont start up get a disk read error press crtl-alt-del to restart though when i do it still does not work
you have a corrupted system, OS is not working...need to re-install OS.
if u r on WinXP then get help from my site
www.sureshayyar.110mb.com
Sep 25, 2010 | Sony VAIO PCV-J200 PC Desktop
The defrag went out in my compaq computer, about 1 year ago. It uses windows xp. I was told that I could reinsert my windows program, and reinstall the defrag., without losing the other programs, that are...
to install a WinXP component u need the instalable WinXP CD(not the cd that came with you PC or a rescue disk)
Switch on PC, let the machine boot WinXP, after u get the Desktop, insert the WinXP CD, after the CD rom loads WinXP from CD, in the opening menu select:
"Install optional Windows Components:
in the next menue, select Accessories and Utilities (Tick the Box)
Click Next and u r done....shut down and re-start...
all the best
Jul 08, 2010 | Compaq Presario 5000 PC Desktop
I turn on my computer, it reaches the XP loading page but restarts before shoowing the logon page. This problem just suddenly occured after i turned on my computer today morning.
XP Logon Screen Does not Appear and the Computer Continuously Restarts
http://support.microsoft.com/default.aspx?scid=kb;en-us;310396
http://support.microsoft.com/default.aspx?scid=http://support.microsoft.com:80/support/kb/articles/q310/3/96.asp&NoWebContent=1
Black Startup Screen Is Briefly Displayed, Computer Restarts Repeatedly
http://support.microsoft.com/default.aspx?scid=kb;en-us;314466&Product=winxp
Access the Recovery Console and extract a new copy of the Kernel32.dll file from the original WinXP CD
1. Start recovery console as described above
2. Insert the WinXP CD
3. At the command prompt, type CD system32, press ENTER
4. Type ren kernel32.dll kernel32.old, press ENTER
5. Type map, press ENTER
6. Go to the drive that contains your CD
7. Type expand drive\i386\kernel32.dl_, press ENTER; Kernel32.dll should be listed as 1 file expanded
8. Type exit, the computer restarts
9. Remove the WinXP CD
The Computer Continuously Restarts
http://www.kellys-korner-xp.com/win_xp_restart.htm
Windows XP Restarts When You Try to Shut Down Your Computer
http://support.microsoft.com/default.aspx?scid=kb;en-us;311806
Auto Reboot On System Crash
http://www.theeldergeek.com/auto_reboot_on_system_crash.htm
By default, when the Windows XP operating system
crashes an automatic reboot of the system occurs. While this behavior can be convenient, the downside is the error message accompanying the crash is not visible. Often times this information can be a great help in troubleshooting the source of the crash. This behavior can be modified in two ways; via the registry or using the System Properties property sheet.
OR
Try if this works.
If you have not made any hardware changes...........
and
If you have another power supply laying around and
if
you are comfortable swapping out power supplys.
do that real quick and see if it boots.
Jun 14, 2010 | Sony VAIO Digital Studio PCV-RZ14G PC...
I bought a Dell Lattitude D630 (windows xp
Ok first do you have the windows xp professional cd to restore your system. That will be your first thing to do if you cannot remember your password. If you do then reload the system to the original state. Let me know if you need any assistant by doing that.
May 26, 2010 | Dell Latitude D630 PC Notebook
I have a sony Vaio and on start up it freezes at the first Vaio logo screen?
click on start menu> click on run (winXp) or start search (winvista or win7) > type in msconfig> click ok
a new pop window
click on startup> on the bottom part click on disable all> click apply and then ok> restart pc
Mar 14, 2010 | HP Pavilion dv9000z Notebook
I don't have driver usb hfs modem, how toget the driver ????
1. Where can I get drivers for my Rockwell/Conexant HCF or HSF modem for Windows XP, or I am having difficulty installing my modem in Windows XP?
Conexant has worked with Microsoft to ensure that many PCI modems are supported using a generic data/fax driver that is available on the XP distribution CD, therefore in the majority of cases your modem should automatically be detected and the generic driver correctly installed. Run the List Modem application (listmodem_app.zip) found on the Modem Driver Assistance page to find out if your modem is supported in the inbuild driver on WinXP. If the answer to "WinXp Inbuild Support" is yes, then your modem will work after upgrading to WinXP even when you run the compatibility test before upgrading and you get a warning. However the XP distribution CD does not have drivers for Conexant USB modems or modems that interface to the PC using the AC-Link bus. The AC-Link bus is primarily used in notebook PC's and some desktop PC's. In these cases it is necessary to download the correct driver from the manufacturer before upgrading to XP. If you get the message shown below and you have a notebook PC use the links below to obtain XP drivers.
Example XP Error Message: xperror.gifIf you do not have one of these PC's it means that the current driver that you are using in your previous operating system is not compatible with Windows XP, however if you have a PCI modem it is very likely that your modem will be supported by the driver available on the distribution CD and will work when you upgrade to Windows XP, and you should proceed with the upgrade. Links to OEM Drivers: carrot.gifSony VAIO Systems
carrot.gifGateway Systems
carrot.gifHP
carrot.gifDell
carrot.gifToshiba
carrot.gifLegend
carrot.gifAcer
carrot.gifNEC
carrot.gifFujitsu
carrot.gifTwinHead
carrot.gifMaxData
Jul 27, 2009 | Computers & Internet
My sony vaio is not booting up and i cant recover it
Go into the BIOS of laptp and change the boot order like
hard disk
DVD
usb
etc.......
then save changes.exit
Apr 03, 2009 | Sony VAIO VGN-FJ170/B Notebook
I am facing a problem ininstalling the driver in my Sony Vaio
There is no original driver for your model available now...
Feb 25, 2009 | Sony VAIO FW Series VGNFW275JH
Sony VAIO NV170P Notebook Logo
90 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
