Question about Car Audio & Video
I have installed a Venturer Stereo car cd player and not getting any power when I put the front face on.
    Problem Solver:
  • 15 Answers
You need to check your fuses in case one blew out, try turning the lights on as the same time as it is quite common to get the lighting wire confused as a power wire and also check the connections from the faceplte to the stereo
Posted on Dec 29, 2008
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
94 Honda Prelude Factory Car Stereo/CD Player
The BUS wires are a serial data link, probably incompatible with other makes of CD player. I'd hesitate to connect it to +12v, this may cause damage. If anything try connecting it to BUS.C through a 1kohm resistor to start with.
Perhaps you need something like this to make it work. http://www.caraudiocentre.co.uk/product_m-alpine-kcm-122b_p-20941.htm
Oct 21, 2007 | Car Audio & Video
How do i eject a cd from the JVC KD G510 car stereo. A CD is already in there but i can't figure out how to get it out and put a new one in
A malfunctioning stereo may least allow feature buttons to perform extractions of CDs. Depending on how the stereo was installed, the car would have to be powered on to attain stereo functionalities. Second, CDs have to be inserted with the readable media side facing the appropriate lenses to achieve results. A wrong insertion of the CD into stereo compartment may require forceful extraction. Observe the type of stereo to ascertain CD extraction also known as reset buttons. Usually a tiny area, the reset button allows inserting an object that forces the car stereo to eject stuck disks. Every mean to eject stereo disk have to be performed while the car is turned on to utilize the source of power. An unsuccessful attempt to dislodge CDs in stereo compartments would require auto electrician's consultation. An unsuccessful dislodge attempt usually requires acquiring a new stereo in replacement of the malfunction.
Feb 02, 2011 | JVC KD-G510 CD Player
How do you fix a cd player on a stereo
Usually fixing CD players on stereoare quite simple and depends on the stereo in question. First you have to check if the stereo has a space for auxiliary port at the back it is usually denoted by AUX if it doesthen the operation is possible. All you have to do is get one of two types of cables depending on what type of CD player. If it is a walkman then you get the cable with Single 3mm earphone jacks to double av. If on the other hand the cd player has the av jack output then you get the normal av cable. connect from the output of cd player to aux of stereo then change the stereo function to aux.
hope this solution has been helpful?
Jan 01, 2011 | Venturer CD2315 Shelf System
Just installed Dual XDMA6330 has no power no lights no sound
the red wire needs to go to a switced power source. unless both the red and yellow wires are getting power, the deck will not turn on.
Mar 12, 2010 | Dual XD7600 CD Player
No power to cd player in car
Did you check the fuses on the car or on the stereo it self?
Jan 19, 2009 | JVC AM FM CD DET FACE CAR STEREO
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
CD won't work
Have you tried using the reset button on the front of the unit (under the face panel)
Jan 13, 2008 | Sony CDX-L400X CD Player
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
