Question about Frigidaire FEF329E Gas Kitchen Range
FRIGIDAIRE GAS RANGE LGLGF388DS
On theLCD display panel, there are continous error messages and a hell of a lot of beeping noises. have to pull-the-plug at night time to avoid the noise/beeping sound. does this thing-ah-ma-jig has a mother board? it's an electronic problem which started just after the warranty expired, isn't that a ... can you please help/advise.
    Novelist:
  • 114 Answers
I WOULD TRY UNPLUGGING YOUR APPLIANCE. TURN GAS COCK "OFF" (BY LAW THERE SHOULD BE ONE NO FARTHER THAN 6 FEET FROM YOUR STOVE) PLUG STOVE BACK IN. SEE IF IT MAKES THE SAME NOISES. IF IT DOES, CALL THE GAS COMPANY TO SEE IF YOU HAVE THE PROPER GAS PRESSURE GOING TO THE APPLIANCE. (SOME GAS COMPANY'S STILL WILL CHECK THIS AT NO CHARGE". NEVER TRY TO REPAIR ANY GAS OR ELECTRICAL APPLIANCES YOURSELF. FIND A LISCENSED APPIANCE REPAIR COMPANY IN YOUR AREA (SEE IF THEY ARE LISTED IN THE BBB AND HOW LONG IN BUISNESS) UN FORTUNATELY, ALL THE NEW APPLIANCES WITH ALL THE NEW "BELLS AND WHISTLES" ARE USELESS AND COSTLY TO REPAIR IN MOST CASES. DONT GET RIPPED OFF MAKE SURE THE REPAIR COMPANY IS CERTIFIED TO WORK ON YOUR MAKE AMD MODEL. Joe_Rex (New Member)
Posted on Apr 27, 2007
1. Microwave noise 2. keyboard and beeping
Make sure oven is plugged into a grounded outlet, and that the outlet is actually grounded.
Although extremely rare, I have seen ovens where insects were walking on the back side of a control panel, and causing problems. Could also just be some sort of electronic failure.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Mar 14, 2016 | In Microwave Ovens
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Have beeping f68 how do we stop the beeping ????
I appreciate your inquiry, friend!
I understand that your Frigidaire range is displaying an "F68" and beeping. I would recommend performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes, which should clear out any miscommunications within your range. If your range continues to display "F68" that could be a high voltage condition. This means that you may have an issue with the voltage coming into your range or your control panel. This is not a simple fix. I would highly suggest consulting with a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 01, 2015 | Ovens
We have the same problem as Kristen with the F68 error on two different Frigidaire FGEF308TNF ranges. Does she have solar panels on her house as we do?
Thank you for your inquiry, Robert Klaum!
I see that your Frigidaire range is displaying an "F68" error code. I am unsure if another member has the same problem due to solar panels. Typically, an "F68" error code means that you have a high voltage condition. This could be an issue with the polarity, supply voltage, or EOC (Electronic Oven Control). I would recommend having a professional technician out to your home for a proper diagnosis to be completed. Best of luck! -Matt
Dec 19, 2014 | Frigidaire Kitchen Ranges
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
FRIGIDAIRE OVEN BEEPING ERROR F 31 MESSAGE
Hello parmantal - Typically error code F31 indicates that the unit has a shorted probe connection problem. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and this will usually clear most false codes. If it proves to be ineffective, contact a professional to move forward accurately. The technician will need to check the resistance and/or harness between the EOC and probe connector. Depending on the diagnoses part(s) will need replacing.
Dec 18, 2012 | Frigidaire FEF352 Electric Kitchen Range
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control panel continously beeps with message to
Could be a faulty control as you suspect but also may be a bad keypad. If the "start" button has no effect I'm suspecting the keypad first.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | GE Profile JT912 Electric Single Oven
Kitchen Ranges Logo
274 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Justin Duby
Justin Duby
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
