Question about Frigidaire FMV157GM Microwave Oven
Fmv158 New fmv158 frigiaire micro. NO power. Outlet ok. ????
Power failure on ge wes1130
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
Oct 15, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    My microwave does not heat as hot as it use to. What would cause that.
    Here is a simple power test.
    Place a measured cup of water into the microwave. Run the micro for 2 minutes. A 1000 watt micro will boil a cup of water in 2 min. Check the power output of your machine. It will be found on the model number tag. A 700 watt micro will take about 3 minutes. If this occurs, the machine is working properly.
    Otherwise, check the outlet voltage, should be 110 or higher.
    Outside of this, you could need a high voltage capacitor or magnetron.
    Dec 30, 2010 | GE Microwave Ovens
    Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
    IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
    Jun 07, 2010 | GE Microwave Ovens
    GE JVM1650WB008 Microwave. Daughter used left
    probably blew the magnetron or high voltage transformer DONT test either unless u discharge the capacitor possible shock risk that unit is still live even unplugged.... i wanna telll you these days that micros are disposable items because the parts are gonna cost more than just to buy a new one plus if any arching occured that same problem is gonna occur again if it did work so basicallly that miro is kapout... hope this helped
    Jan 31, 2010 | GE JVM1650 1000 Watts Microwave Oven
    Emerson microwave mw8773sl has no power, no lights
    Make sure that a lamp will work in the outlet powering the microwave. If ok, remove the case (with the plug pulled), and look for a tripped breaker or blown fuse. If found, check for a shorted high voltage diode in the magnetron power supply. It may also have a shorted stirrer bearing located above or beside the cavity where the microwaves come into it. The stirrer is a metal fan-like device that scatters the microwaves to get more even heating and has a plastic bearing that arcs internally causing a microwave short. Replace the stirrer unit.
    If no fuse or breaker troubles, look for faulty or loose micro-switches around the door latch mechanism.
    Aug 23, 2009 | Microwave Ovens
    No Power
    HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
    Jun 01, 2009 | Kenmore 62702 Microwave Oven
    New spacemaker microwave lost power. checked the outlet for power, it is good but no power to the micro.
    Being new, it would be under warranty, so I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Jun 01, 2008 | GE Microwave Ovens
    Microwave has no power
    Is the outlet ok? Can you plug somethng else into the outlet to see if the fuse or breaker controlling the outlet is ok? If there is power at the outlet, unplug the unit and remove the outside cover.
    Look for a blown fuse on the motherboard. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged. Was this a power outage or surge? Was anything else in your home affected?
    - Jim
    Jan 29, 2008 | Goldstar MV-1526 Microwave Oven
    Frigidaire FMV157GM Microwave Oven Logo
    Top Frigidaire Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
