Question about ATI RADEON 7200 (64 MB) Graphic Card
Upgrading graphics card
I have Radeon 7200 and I just got a Dell S2009W flat screen monitor. When I hooked it up it said I needed to set the display resolution to 1600 x 900. I don't think my graphics card will set to that.. I need to upgrade my graphics card, how do I do that?
  • mederbil May 11, 2010
    What is your computer model? Do you know if it uses an AGP or a PCI-E graphics card slot?
    Genius:
  • 2,920 Answers
According to the manufacture your card has the resolution up to 2048 X 1536 that is higher than what the monitor is telling you to set your resolution to. try going into your display options and ajust the resolution down to 1600 X 900. Also since your monitor is a dell an new it should come with an set-up disk for that monitor that should once intalled set the monitor to the correct graphics setting for you so you do not have to go through and do it manually. did your come with a disk? If not here is the link to download the drivers for your monitor.
http://support.dell.com/support/downloads/download.aspx?releaseid=R194543&formatcnt=1&libid=0&fileid=271546
please let me know if you need further assistance in this matter.
Posted on Dec 28, 2008
16:9 resolution problem
You don't specify your machine type, or the operating system, but let's assume a desktop computer and Windows XP...
Was the monitor recognized properly by the video driver?
Go to Display Properties, settings, advanced, monitor and see if Plug and Play monitor is installed. All modern graphics cards talk to the monitor to discover it's capabilities and should adjust the available resolutions so that the monitor's native resolution is available for choosing.
If some other monitor is listed there, change it to Plug and Play monitor. If still having troubles, you can do two things:
- update the video driver for your graphics card
- find the monitor's .inf file (it should be on a CD that comes with the monitor, or can be downloaded from DELL site), and install this instead of the Plug and Play monitor or whatever you have in your monitor setup (as above, go to monitor - properties - update driver).
Nov 08, 2009 | Dell Computers & Internet
An incompatible video signal has been received check the output device settings connecting a sharp aquos to my ati radeon HD2400
what the problem is your pc is displaying a resolution you monitor cant display most likely its to low do you have a 2nd monitor you can hook up to set resolution Once you have done that set resolution that your new monitor can take and then hook up . when i moved from a 19inch monitor which ran at 1280 x1024 to a 32 inch samsung 1360x768 i had same problem as my screen cant display that res so set to what ya monitor can do .If you dont have a second display keep connected turn pc off with only your sharp cable in and it should turn on once into windows
Oct 07, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Can i put a ati radeon 9550 graphics card in a dell dimension 2400
You can put any graphics card in any machine you just need to install the proper driver
Use to be a jumper on the mother that disabled the onboard video but today I think the soft hardware saves use the trouble.
You can run 2 monitors at one time using the 2 video graphics... card and the one on board just set you display properties
Jul 30, 2009 | ATI RADEON 9550 Graphic Card
Duel Monitor Problem
first thing first ensure that you have the latest ATI radeon X1600 pro driver and software installed else you won't be able to get the desired options for dual display under settings coz it will be working with generic drivers.
To download the latest driver and software click here
Then please click the following link :
ATI Radeon X1600 PRO How to
On this link click on the option
  • "Guides, Walkthroughs and "How to's"
Then opt for
  • "How do I use dual displays or TV/HDTV out? "
Just follow the instructions.
Feb 19, 2009 | ATI RADEON X1650 Pro, (512 MB) PCI...
Dell 1702FP 17" shows nothing after Radeon HD 2600 put in.
Is the card plugged into the (PCI/AGP) slot correctly? Did you disable the onboard video in the bios? Also be sure to check in windows device manager and check for the graphics card to appear there.
Dec 24, 2008 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Upgrading Graphics Card
So your dell only has a AGP slot.
You need a AGP card
On nvidia side you can get
The geforce 6000 - series
Geforce 7000 series
On Ati side you can get
Radeon x1000 series
Radeon HD 2000 series
Radeon Hd 3000 series
Remember they have to be AGP
May 26, 2008 | Dell Dimension 8100 PC Desktop
HIS Radeon X1300 Misdetected
do the BIOS update !
in the advanced BIOS features there should be a onboard GPU tab, put it on disabled or on initiate AGP/PCI first (depends on the BIOS), so to be sure that the onboard card is disabled !
Connect the display to the HIS ...video card , and at least on bootup there should be info displayed on the screen . If not than : - try to reinsert the video card (bad connection ) (also check if its a card that needs external power source ( i doubt it))
- check if the video card is compatible with the motherboard (should be in the user manual, or on the producers site ... )
- check on another comp. if the card is good ....
hope it helps u ... if not, give more details ....
Jan 21, 2008 | HIS X1300 RADEON X1300 PCIe 512MB (128 MB)...
No image
try control panel, dispaly settings, monitor, change default monitor.
Let me know if this works for you.
Jan 15, 2008 | ASUS A9250/TD Radeon 9250, (128 MB)...
Dell m992 monitor screen width
The link below is a Digitally signed M992 monitor driver. http://support.us.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R44148&formatcnt=1&libid=0&fileid=51992 Also try upgrading to the latest ATI software and drivers. You can also try and change the frequency refresh rate to 75mhz. It in the Control Panel under 'Display' and tab 'Monitor'. It shows a list for frequencies you can try.
Oct 02, 2007 | Dell M992 19" CRT Monitor
ATI RADEON 7200 (64 MB) Graphic Card Logo
160 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
