Question about Microsoft Windows XP Home Edition
D:/I386 file can not be copied during installation.
I am trying to reinstall XP Home due to some corropted files and Keep geting messege that files coul not be copied. Pointing to different location does not help since screen locks up. Please help.
  • 1 more comment
  • haresh_pandy Dec 29, 2008
    I am trying to do repair.
  • lawfirmgwc Feb 05, 2009
    I notice the error occurs frequently during attempted repair of Windows. Often times the files are already on the disk. I don't know if there is a virus that is preventing the files from being copied or Windows notices that I have newer versions of the files and thus won't copy them, but either way, it doesn't copy.
    Would it be safe to delete many of the files from the hard drive and then do the repair option?
    By the way, Windows XP "repair" doesn't work because it asks for a password and even the correct password doesn't work (you can verify this on the MS website). You can choose "install" and then it will say you already have Windows, do you want to repair, at which time you can repair without a password.
  • oneputtjo May 11, 2010
    are you doing a reformat or repair.
  • 78 Answers
Try this to check the harddrive for errors and fix them.
Boot from you XP CD.
Type "R" to repair.
Type "1" to C:\windows
Enter Administrator password if ask, you have to know this or else, it might be nothing so just try enter if you don't know it.
At the DOS prompt type: chkdsk c: /f
this will take a long time to run, several minutes so take a break.
After it finishes, reboot the XP CD again.
Type the Enter key to setup Windows XP now.
Type F8 to agree.
Type R to repair C:\windows
(you will need your software key now, sticker on your computer)
If the drive isn't going bad and with any luck this might fix it.
Posted on Dec 29, 2008
    Novelist:
    Scholar:
  • 72 Answers
PegBox made some valid suggestions. I have seen this before where a repair would not work, but a full format and re-install would work fine.
I suspect you are trying to salvage data and thus the repair. An alternative it a parallel install where you install Windows in a different directory. If it works, you can back up the files. When they are safely backed up, format the drive and wipe out everything for a re-install.
If it does not work, you may be able to install on a new or temporary drive, and be able to retrieve files from the old drive. Once you have your files, reformat the old drive and see if it works.
    Scholar:
  • 51 Answers
Files get corrupted by a virus or a flaky hard drive. Since you are having trouble with reinstall, I suspect your hard drive is going bad. Suggest you get another hard drive, even temporarily, and try to install on it. Be sure to pick the FULL format, not the quick one. You don't say how old the motherboard is, but the typical "leaky capacitor" problem, scratched XP CD, or even a bad CD-ROM could also be considered.
While installing xp sp3. Error message: file missing check i333
Are you sure i333 is not actually i386? The i386 folder contains all the files Windows uses to install XP. If you have XP installed already and it is asking for the i386 folder, it wants you to put the original Windows XP folder into your CD drive. If you are attempting to install Windows XP with SP3, there is something wrong with your CD. To avoid this problem in the past you can do this:
Copy Windows XP Installation Files to Local Hard Disk SourcePath Raymond CC
Feb 07, 2017 | Computers & Internet
Tip
How To Install East Asian Language Support In XP Without XP CD
  1. First, check to see if you have the i386 folder on your hard drive. This folder will have the East Asian Language Support files that you need to install. The i386 folder can be found here: C:\WINDOWS\Driver Cache\i386 or here: C:\i386
  2. If you cannot find the i386 folder, you will need to obtain a copy of the Windows XP CD and copy the i386 folder to a USB thumb drive.
  3. Click on the Start menu, open Control Panel, then open Regional and Language Options.
  4. Select the Languages tab and under the Supplemental language support frame, check the the box next to "install support for East Asian languages".
  5. Click on Ok or Apply, then you'll receive a dialog box which says that "The following file ' - ' is missing.." and it also allows you to specify a directory where it should be found. Click on Browse and select the "I386" folder on your hard drive or thumb drive.
  6. After the files are installed, you must restart your computer.
on Feb 26, 2011 | Computers & Internet
Una to reinstall. Get this MX: ''Error 1305.error reading from file EmsworkspfilesC3WizardsSTUSSus.dat. Verify that the file exists and that ypou can use it. ?: How do I verify?
You have to check that the disc you are installing from is not damaged or if it is a burned copy is not a bad copy.
Anytime you get this error during a reinstall or install of windows it is due to the installation disc having a problem. occassionally you will find a bad drive but rarely the case.
Feb 12, 2010 | Microsoft Windows XP Home Edition
NTLDR IS MISSING for HP 530
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
    Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jul 28, 2009 | Computers & Internet
I upgraded my motherboard, but now when it boot ups nothing happens. the monitor shows a boot menu (gigabyte), and flsh on and off, Is it the motherboard on the reset switch. I took it to Staples and they...
See if you have the operating system installation cd with you then try to repair the boot menu files howeva if that dont work out then install the operating system and that should resolve your problem.
How to Repair the Boot Sector:
If XP won't start it may be due to a damaged boot sector or a missing or corrupt ntldr or ntdetect.com files.
To replace damaged ntldr and ntdetect.com you can copy fresh files from the XP CD using the COPY command. Boot with the XP CD and enter the Recovery Console (as above). At the Command Prompt type the following (where "X" is your CD-Rom drive letter) allowing the files to overwrite the old files
COPY X:\i386\NTLDR C:
COPY X:\i386\NTDETECT.COM C:
To repair a damaged Boot Sector at the command prompt type FIXBOOT and press Enter. Then answer "Y"
Jun 25, 2009 | Office Equipment & Supplies
Acer Aspire One Zg5 Audio driver not getting installed
Certian device driver installations might require existing system files to be modified which in return calls for the Windows Cab files which are normally in the i386 folder located on the Windows XP CD. If you have full access to this computer then all you have to do is find or borrow someone else's Windows XP Home CD and copy the i386 folder from the CD to somewhere on your local disk, root of C drive (C:\i386) would be fine. Then open the registry (Start > Run > regedit > OK) and modify the following value to point to the i386 folder.
Expand each of the following key: HKEY_LOCAL_MACHINE - SOFTWARE - MICROSOFT - WINDOWSNT - CURRENTVERSION, after you click on CurrentVersion on the right hand list, look for the value called "SourcePath". Double-click on 'SourcePath' and change its data to read C:\i386 (assuming that is where you copied that entire folder). Close registry editor, reboot and try installing the drivers again.
Apr 02, 2009 | Computers & Internet
My computer Desktop is not running.
Hi hichris_4u
You should be able to replace the Explorer.exe. Type in the command prompt expand C:\I386\explorer.ex_ %systemroot%\explorer.exe This will expand a new copy to the windows directory.
You should also download a new version of SP2 and reinstall it. You also could download a clean copy of SP2 Click the Download button. The file is 266MB. Create a folder on the C:\ root called SP2 and download it there. Create another folder called SP2 files now at a command prompt type C:\SP2\WindowsXP-KB835935-SP2-ENU.exe /x it’ll ask you to specify an directory so point it to the SP2 Files folder and let it extract there. Now type in the command prompt expand C:\SP2 Files\I386\explorer.ex_ %systemroot%\explorer.exe to expand a new copy to the windows directory.
If you get an error on destination, try expand C:\SP2 Files\I386\explorer.ex_ c:\windows\explorer.exe
If you expanding fron the I386 from the C:\ root try expand C:\I386\explorer.ex_ c:\windows\explorer.exe
If all fails, try and download SP2 onto another machine and then burn it to a CD for install.
Good Luck,
Mark
Mar 26, 2009 | Microsoft Windows XP Professional SP2
Ntldr error on ibm intellistation z pro w/ xp pro
During the XP install, you will be given the chance to set up partitions on the drive. Blow them all out. Completely. Then recreate the partition and let XP install. I expect this will solve the nt loader issue. If, however, it does not, then use the recovery approach below to get the required loader files onto your boot partition.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "d." This letter may be different on your computer.
    copy d:\i386\ntldr c:\
    copy d:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Mar 04, 2009 | IBM IntelliStation Z Pro 6221 PC Desktop
Windows Xp Home edition Installation
Hi tross202;
Is that an original XP home edition installer? You may try another cd installer if you can secure one.
Jun 01, 2008 | HP Compaq Presario SR1420nx...
Win xp pro setup
if you have the original xp disk with a cd key , then its perfectly legal for you to download a iso copy of xp , and install it, if not try and make a copy of the disk , and use that , or someone u know may have a friend with a xp disk , thats fine also aslong s you use the key that comes with your disk
Nov 26, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Home Edition Logo
571 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
