Question about Dometic RGE400 Top Freezer Refrigerator
Dometic rv fridge heats up rather than cool down when turned on.
The motor home has been sitting still for 8 months before i bought it. Someone said to try shocking it by hooking up 110 and propane at same time. does anyone know how this is done.
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
SOURCE: Dometic RM2607 Sitting for 6 years now has cooling issue?
ae359t is right replace the board, its not the cooling unit itself nor does it need to be turned over upside down, you only mention the controls are wacky, get the bottom board for the $99 price, if that does not fix the unit replace the upper eyebrow board, very seldon do upper boards go out.
Posted on Aug 15, 2009
  • 332 Answers
SOURCE: last year my dometic rv fridge would run fine on
Here is an interesting possible problem to look in to
First a bit of background on LP gas
Your LP system operates on 1/2 lb of pressure Not much more than a breath of air. Keep this in mind for a minute.
A lot of RV's have been built over the years using rubber hoses to connect LP gas to water heaters, furnaces, and refers.
Over time rubber and LP gas create an oil, if you have a low spot in your rubber line that oil will collect in the low spot - - Remember the 1/2# of pressure from earlier? Does not take a lot of oil build up to over power the 1/2 # of pressure and now you are not getting LP gas to your refer.
This is one possibility. The lines will need to be removed from the refer and other low setting items like the water heater and furnace also from the LP tank regulator and the using NO MORE THAN 10 pounds of air pressure blown out. BE VERY CAREFUL this oil is some really nasty stuff - cover the ends of the lines with a cloth in a plastic bag with some holes poked in the bag and rubber band it on.
But first lets look at some other options
Your refer has to have 12 volt power to it to operate
90+ % of all 12 volt issues are grounding problems.
Make sure you have at least 12 to 13 volts to the refer and that you have a good ground.
Next Are you getting gas flow to the burner?
If you are getting gas try changing your thermocouple They run a couple of buck and is an easy test.
If you have 12 volt power and gas have you noticed an ammoina smell?
This model has been known to lose the cooling unit
Hope this helps
Coyote
Posted on Mar 31, 2010
motor1258
  • 6674 Answers
SOURCE: 3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Posted on Jun 22, 2010
SOURCE: i have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Posted on Aug 18, 2010
What is the roll over procedure for a dometic rv fridge?
The procedure that you are probably thinking of entailed turning the refrigerator upside down for 24 hours, then righting it and turning it on. Though doing this will not hurt the unit try checking these things first,
  • Door closing properly? Check the door gasket.
  • Overpacked refrigerator? The unit will have to work harder if the refrigerator is stuffed and results in higher cabinet temperatures. Arrange the food in the unit to allow for free air circulation.
  • Is the burner dirty, damaged or not properly located under the ue tube?
  • Is the burner jet clogged? is the flame " clean?"
  • Is the ue baf e inserted properly in the ue tube?
  • Is the LP gas pressure low at burner?
  • Is there proper air clearance behind and around the unit?
  • Check the tubing behind the unit, is it damaged ? leaking?
Aug 26, 2016 | Dometic Refrigerators
How do you hard reset a dometic rv fridge
Yes they can. All you have to do is disconnect the fridge and pull it out of the rv, flip it over on its top, let it sit there for a day or two, then put it back in and away you go. What happens is the mixture inside the fridge separates which does not let create a cooling process. When you flip it over it mixes the gasses together again then away you go.
Sep 07, 2012 | Dometic Refrigerators
Large fridge & freezer in caravan. Works fine on mains electric but fails to cool on gas. The pilot ignites and fridge cools very slightly on gas
IN THE PAST I HAVE TAKEN THE UNIT OUT AND TURNED IT UPSIDE DOWN, AND LEFT IT SIT FOR ABOUT 1 MONTH. THEN REINSTALL THE FRIDGE, AND IT WORKS AGAIN.. .. REASON YOU MAY ASK ? THERE IS A LITTLE BULB THAT THE FLAME KISSES, AND IT SEEMS IT GETS TRASH INSIDE THE BULB, AND SLOWS THE HEAT TRANSFER .. YA I KNOW IT SOUNDS CRAZY, THAT'S WHAT I THOUGHT ALSO.. OH AND TO OPERATE THE UNIT NEEDS TO BE LEVEL (CHECK THIS FIRST !!) ..LAST ONE I DID WAS ABOUT 25 YEARS AGO..
JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jul 20, 2011 | Dometic Refrigerators
Our rv has a dometic rm2600 fridge that smells of ammonia inside and has a little bit of yellow residue in behind service panel. is the fridge wrecked or is it worth repairing. the rv is 27 years old.
Sorry to give you the bad news. The ammonia smell is the the refrigerant
leaking out. Dometic uses ammonia that is heated and then condensed to cool. It will all leak out and quit cooling.
The fridge is wrecked. There are shops that rebuild the units. Beings as ammonia is corrosive one must assume there may be other leaks ready to appear. There are RV salvage yards that sell good used units.
Again Sorry for your loss.
Apr 27, 2010 | Dometic RM2620 Refrigerator
NDR 1292
Make sure the condenser fan underneath the unit is running when the compressor is. I don't know what else it could be unless the door gaskets are in bad shape.
Aug 20, 2009 | Dometic NDR 1292 Refrigerator
you can turn it upside down for 2days and try it again
May 15, 2009 | Refrigerators
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
174 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
