Question about Archos 605 Wifi Portable Multimedia Player
I have just purchased an Archos 605 wi fi 160 GB player but my computer wont recognise the player through the usb cable ( My operating system is windows XP home )
  • 395 Answers
You can get the current firmware and downloads from the archos web site at
http://www.archos.com/support/support_tech/updates.html?country=global&lang=en
Posted on Dec 28, 2008
Archos 2 OC won't charge and is not recognised by laptop
Sometimes with mp3 players the cable is the one that is mostly damaged. Try replacing this cable and try again. It actually has happened to me on two different mp3 players. Cables are always faulty.
Jul 12, 2012 | Archos 2 (8 GB) MP3 Player
Wont install to computer
On the Archos:
In the settings menu from the front screen, set your Archos to 'PC Hard Drive' instead of Windows Media Player.
If it doesn't show as an external hard drive when you plug it into your pc, do this....
On the pc:
Go to Start\run, type diskmgmt.msc and click ok to take you into Disk Management.
Your Archos should show as a drive in here and you can associate your new drive with a drive letter.
If you cannot see your Archos in this windowafter you've set it to 'PC Hard Drive' on the Archos, then you may have a dodgy usb cable.
Hope this helps......
Jul 19, 2010 | Archos 605 WiFi Digital Media Player
Archos 605 running Vista Computer does not recognise the archose
Go to settings and look under system.Then look where it says usb peference then see if it says windows media device if not change it to this and if that doesnt work try the other settings.If that doesnt work go to Archos.com and contact them and see what they can do.
Feb 06, 2009 | Archos 605 WiFi Digital Media Player
Not recognised under USB
if you are having technical problem with your archos 605 just do this connect your USB with your computer and your archos device will pop up on the screen asking you if you want to charge your device or enaable usb that will automatically appear if your computer doesen't reconise the device then switch it off and on again if doesen't work then i suggest you look it up on the archos manual which is located on your device. if that doent work then i think you may need to update your computer it must have windows Core dual processor if that don't work and your archos device doesent appear then i think you may need to update your computer with a service pack 2 installation cd
Oct 01, 2008 | Archos 605 WiFi Digital Media Player
Since returning my Archos 605 wi-fi 160 gig to it's factory state I can no longer sync protected WMA's with WMP 11, HELP
the problem has been fixed wit help from your site and others. After checking drivers etc. I down loaded Windows Personal Care and ran it, after using a number of tools to look at different aspects of my computer I was no further forward, but with WPC the problem was fixed within about ten minutes. I wholeheartidly recomend tis oftware to any and everyone,
Simon.
Jun 24, 2008 | Archos 605 WiFi Digital Media Player
Archos 604, frustrating problem.
Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
Mar 24, 2008 | Archos 604 Digital Media Player
Archdfios 605 wi
mine's just gone a similar way - made a playlist and saved it...all songs were playing ok up until then. When i went to play the playlist it told me that the file was corrupt then proceeded to tell me all 14000 songs were corrupt...just in the middle of an attempted repair!
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
Unable to regester my 605 wi-fi
PLUG USB CORD IN AND GO TO THE SITE WWW.ARCHOS.COM AND REGISTER YOUR UNIT.
Jan 06, 2008 | Archos 605 Digital Media Player
Archos not recognised by both my computers
You must update the firmware on the archos.
Dec 07, 2007 | Archos 605 Digital Media Player
Archos 605 in demo mode
We called tech support and you fix it by doing a reset on the base of the device. We used a paperclip to push the button. Hope this helps!
Oct 28, 2007 | Archos 605 Digital Media Player
Archos 605 Wifi Portable Multimedia Player Logo
145 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
