Question about Toshiba 42H81 42" Rear Projection Television
HDTV does this tv have a digital tuner
  • 22 Answers
Sadly, no. While this TV is HiDef ready via the color stream inputs, the tuners are old-style NTSC. Shouldn't pose a problem if you're using cable or satellite.
Posted on Jan 05, 2009
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
I want to say it does but if it doesn't, just do what I do, My VCR sends the signal to the TV via input 1. Let the VCR change your channels and alas you can record without fancy wiring.
Posted on Dec 28, 2008
  • Toshiba Master
  • 5,568 Answers
In short; yes.
The only shortfall I saw was its inability to handle 1080 resolution directly but can display 1080 signals in a mode known as 'interlacing' which is done at half the available vertical scan rate and is written as 1080i.
You can see a review with specs here:
Toshiba HDTV
2 Suggested Answers
  • 350 Answers
SOURCE: does this tv have a digital tuner?
Sorry to say, your HDTV-Ready - Requires separate receiver to view HDTV signals. SDTV (Standard Definition) - has built-in digital receivers/decoders and do not require the purchase of any separate components in order to display digital signals. It provides lower image quality than EDTV or HDTV, but higher image quality than analog TV. SDTV is displayed using an aspect ratio of 4:3. I hope this helps and good luck.
Please remember to vote fe52ba2.jpg if this was helpful in any way. Thanks.
Posted on Oct 31, 2009
How do ihook up a digital antenna to my tv
Dominic, you do not state whether you want large outdoor antenna or simple indoor.
If you bought your HDTV anytime during the past 8 years or so, it should have a built-in tuner for receiving digital over-the-air broadcasts. If you have an older "HDTV-ready" TV that only receives analog signals, you'll need to connect it to a separate HDTV tuner.
link below tells how to install outdoor digital TV antenna.
press the helpful button.
How to Install Digital TV Antenna Digital TV Help
Jan 19, 2016 | Televison & Video
I have an RCA HDTV 52" Rear Projection tv.. do
No they do not have digital tuners inside them. They are meant to be monitors to converter boxes, cable boxes, and satellite television receivers.
Jul 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I would like to know if the Hitachi 51UWX20B television can be connected to the internet.
Your Hitachi 51UWX20B is an HDTV-Ready TV. No Digital Tuner. HDTV-Ready means that your TV set is capable of displaying analog and high-definition digital pictures, but without a digital tuner, it cannot receive the digital signal. An HDTV-Ready requires an external high-definition TV receiver (digital tuner) in order to receive HDTV signals. These external receivers can be called an HDTV Tuner, set-top-box, decoder or DTV Converter Box . So you will be required to purchase a converter box to receive over the air programming from an external antenna.
Jul 03, 2010 | Hitachi 51UWX20B 51" Rear Projection...
We have a phillips model #32PFL5332D/37 it has a flat screen. Is it digital or analog
Yes this TV should tune to both Digital & Analogue reception. See below I have copied an extract from the Philips technical site which gives you verification that this has digital capability. Hop this is of help to you. Next to analog NTSC broadcast reception, your TV has an integrated High
Definition TV tuner which receives, decodes and displays terrestrial ATSC and
unscrambled cable (QAM) signals.
HDTV quality is only reproduced when a broadcaster or cable provider broadcasts
HDTV signals.
Jul 24, 2009 | Televison & Video
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Vizio P50HDTV10A 50 in. HDTV Plasma HDTV Tuner out
The HDTV tuner is out. Analog tuner, and video inputs work fine.
TV Model P50HDTV10A
Screen Size 50 in.
TV Manufactured Date Jan 1, 2007
Alternate Part Type SIGNAL BOARD
Part Number 3850-0042-0150(3A)
Alternate Part Number 0171-2272-2163
Jan 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
Are 2 tuners needed for HDTV
No, You need 2 tuners for PIP (Picture-in-picture). Perhaps the confusion is that some HD TV's do not include tuners at all. This is fine if you are going to be getting a cable or satellite box for satellite or digital TV. But it's best to cover your bases and make sure the TV has a built-in tuner. 2 tuners are not needed and not all that common.
Sep 03, 2008 | Televison & Video
1 Answer tuner?
yes it is a digital tuner but does not mean it is a hdtv what are you asking about. let me know im curious i would like to help maybe all you neede to know if it is a digital tuner yes it is
thanks doctor video leadingedgeelectronics since 1987
Apr 27, 2008 | Sharp 20L-S100B 20" TV
Toshiba 42H81 42" Rear Projection Television Logo
88 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
