Question about Maytag SAV3710AWW Washer
I have a maytag washing machine model #SAV3710AWW. The water will not drain and it smells like a belt is burning
    Genius:
  • 2,920 Answers
You may have a sock stuck in the drain keeping it from draining. the burning belt would be from running it and trying to get it to drain when it cant
Posted on Dec 28, 2008
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Burning rubber smell from my maytag stacker washer and the water wont drain
Most likely the water pump belt is slipping or the water pump could be locked up.
Sep 03, 2010 | Maytag LSE7806A Top Load Stacked...
Tub not spinning smell rubber
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Some part of the motor burned out that's why you can smell burning rubber. Check some faulty parts.
Mar 28, 2010 | Maytag Washing Machines
It does not drain at all? and it makes a weird noise and it smells like burning rubber how do i fix it? some one told me that it might be the pump.
Mar 27, 2010 | Maytag MAV2755AWW Dependable Clean Top...
Maytag washer MAV208DAWW does not spin out the water completely from clothes after spin cycle.
do you smell anything burning or a burning oder,your belt could be glazed from over loading the washer and now the belt is slipping,also check the drain hose for kinks making for a slow drain,do you hear any noises when draining like something could be stuck in the pump, maybe to much detergent and it's oversudsing, or you could have a bad trainy,check the belt first belt part number is 21352320 and it's around 25 bucks
Feb 26, 2010 | Maytag Washing Machines
My Maytag A105 Washing Machine made a weird noise just as it started the spin cycle. When I opened the top lid, there was a burning smell and I could see some smoke coming out. I shut the lid again and...
This sounds like a belt burning. Something may have got caught in the pump and the belt is slipping and burning. You will need to drain all the water out first. Then remove the front panel. Tilt the machine back a little so you can reach the pump pulley and see if it turns freely. Your model has 2 belts and they both should be replaced at the same time. Adjustment on the pump belt is critical so the drive belt doesn't slip. If something is caught in the pump, whatever it is needs to be removed, or replace the pump.
Jan 03, 2010 | Maytag Washing Machines
SMELLS LIKE SOMETHING IS BURNING WONT AGITATE OR DRAIN
Sounds like a belt has gone bad. Tip the waher toward the wall. You might see two belts. If you do not, get me you model # and I will see exactly what nodel you have.
Please let me know if I can assist you further
Thanks
Vic
May 16, 2009 | Washing Machines
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Maytag SAV3710AWW Washer Logo
165 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
