Question about 3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Access Point
Cannot connect my modem to xbox live
Done all diagnostic tests through xbox360 only fails on xbox live ,i am using tiscali wireless modem connected directly to xbox with ethenet cable,HELP
    Scholar:
  • 98 Answers
Try disconnecting your Xbox from the modem, turn both off, wait 60 seconds.
Reconned the Xbox to the modem, turn the modem on, wait 3 minutes, then turn your Xbox on. That should work.
Posted on Mar 19, 2009
Download new drivers for your router, you that have routers,
I had the problem with that it said mtu was disabled or something,
Got alot of tips to change my mtu on http://192.168.1.1 (router settings page)
Tried that but it was all fixed after i downloaded new firmware,
Posted on Mar 23, 2009
Cant connect to xbox live
Make sure you are connected directly to the modem if you are using the usb cord .If you are using the wireless adapter make sure the code u imputed corresponds with your own.
Nov 15, 2010 | Microsoft Xbox 360 Console
Tip
Connect your 3g mobile broadband to an xbox360!
Have you ever wonder if you could connect your 3G mobile broadband modem to your xbox360? Well i have done it and it works fine.
What you will need to do is enable network sharing in your laptop/pc
I am using a vista laptop and orange mobile boradband, and this is how i done it!
First of all connect your 3G modem to your laptop/pc as you normaly would. Now get an ethernet cable and plug this into your laptops ethernet port and then into the back of your xbox's ethernet port.
Click on start> connect to> Then you will see "open network and sharing center" Click that. In the next window you will find all networks connected to your laptop/pc. You will see one below your normal internet connection called unidentified network. Click "view staus" Now in this window click and go to properties. now in this window click on the network tab at the top of the window. While now in this window click on enable network sharing via this device. Now go to your xbox360 and try to connect to Xbox live if at the first atempt it did not work test your connection via xbox as it will ask you to do this anyways. You should now be eable to connect to xbox live using your 3G modem.
Hope this helps!
on Dec 28, 2009 | Computers & Internet
Ok ive trying to get xbox live by connecting my laptop that has a verizon usb 760 modem to my xbox with a ethernet cable no luck yet ive done the bridge but they bridge and also done the sharing no luck...
support.xbox.com/.../xbox360/XboxLive/GetConnected/.../WindowsICSConnection.aspx -22 hours ago -
support.xbox.com/.../xbox360/XboxLive/GetConnected/.../RouterConnection.aspx -
www.ehow.com/how_2268792_computers-wireless-internet-connection-xp.html - United States - 11 hours ago -
http://www.youtube.com/watch?v=0_7BU1DA4EU
A Video how to above, above that How to do it web sites TOP one will be best.
Mar 28, 2010 | Microsoft Xbox 360 Console
When testing the connection for xbox live it can't find the IP address.
Xbox 360 Connection Tests: IP Address
This test verifies that your Xbox 360™ console has a valid IP (Internet Protocol) address.
If your console does not pass this test:
Confirm that there are no other devices on your network with the same IP address.
If you are using a router or gateway, verify that it is configured to assign IP addresses to network devices (DHCP-enabled).
If you are connected to a router, make sure that your console'sEthernet cable is not connected to the router's LAN port rather thanits WAN port.
If you are connected directly to a modem and your ISP (Internetservice provider) requires PPPoE settings, verify that your PPPoE username and password are correct. If your ISP doesn't require PPPoEsettings, remove the PPPoE user name and password settings.
If you are connecting directly to a modem and have replaced a devicethat was connected to your modem with your Xbox 360 console or anotherdevice, turn the modem off and back on before connecting the newdevice.
If you are using a static IP address from your ISP, verify the address with a your provider.
If your console is connected to an ad-hoc network (in which devicesare connected directly to each other), it will probably not pass thistest. If your IP address is assigned automatically and your ad-hocnetwork does not include a DHCP server, this does not indicate aproblem. The test is properly reporting that a DHCP server could not becontacted. Xbox Customer Support does not support the use of ad-hocnetworking to connect to Xbox Live.
If you're using an ad-hocnetwork without a DHCP server and you can't connect to Xbox Live, checka different diagnostic test for the root of your problem.
This comes from http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testipaddress.htm
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 31, 2009 | Microsoft Video Game Consoles & Games
My xbox live doesnt work
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
Xbox360
Hello taz1028,
In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
Sincerely,
Agent Xiong
May 31, 2008 | Microsoft Xbox 360 Elite Console
Xbox live connection
how do I connect a wireless controller (microsoft xbox360) to the xbox360?
Mar 29, 2008 | Microsoft Xbox 360 Console
three is the network
connect and install three usb modem
connect xbox to pc with ethernet cable
then start right click my network places and go to properties in network connections right click 3 usb modem then properties then advanced, tick the box allow other network users' then okay
now connect 3 3g device turn on xbox and BINGO !
Dec 15, 2007 | Microsoft Xbox 360 Console
Cant connect to xbox live through router
Hey stchivo, not entirely sure what's happening.  It might help to know what type of router you have.  I know the new linksys routers have a new security feature by the name of SES or something of the sort.  Make sure that is disabled and that DHCP is enabled.  Also make sure a firewall on the router isn't blocking it.  It might help to have screenshots of your router settings to better evaluate what's happening.
Oct 15, 2007 | Microsoft Xbox 360 Console
Open Questions:
See all 3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Questions
3Com 7760 (3CRWE776075US) 802.11a/b/g Wireless Access Point Logo
349 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
