Question about Motorola Mobility RAZR V3
LOCKED OUT I GUESS
I HAVE A RAZR V3, EVER SINCE I FOUND THE USB CABLE AND PLUGGED IT INTO THE PHONE, THE ONLY SCREEN THAT I CAN GET IS FOR THE VOLUME.ANY BUTTON I PRESS DOES NOTHING BUT RAISE THE VOLUME
I CAN'T ACCESS ANYTHING ELSE AND I CAN'T MAKE ANY CALLS.
I TRYED CLEANING THE PORT FOR THE CABLE THINKING ONE OF THE TERMINALS IN THERE MAY HAVE BEEN STUCK.
IT SEEMED TO WORK FOR BIT, BUT APPARENTLY THAT IS NOT THE PROBLEM.
ANYBODY HAVE ANY SOLUTIONS,,,,PLEASE.
  • decayofthean Dec 28, 2008
    ITS ACTUALLY DECAYOFTHEANGELS@YAHOO.COM
    Brigadier General:
  • 7,752 Answers
You may need to have the firmware flash on the phone and the flexcable replaced.
Posted on Dec 28, 2008
I need to transfer mucis to my phone via a a usb cable
Basically, you can use P2K Commander along with the help from this guide: http://www.somelifeblog.com/2007/01/motorola-razr-v3-how-to-charge-and.html
You need to make sure your cable is a USB 2.0 cable!
Source(s):
Apr 13, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Verizon Razr V3 with locked screen. Verizon
yes ,down load p2k or another flashing utility,then flash your phone
Mar 11, 2010 | Motorola Mobility RAZR V3
Razr v3 ph sig errror 35:02
You will need to purchase a usb cable and download the software disc. If you bought this phone brand new, it should have come with both and so I would contact the manufacturer.
Jun 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How do i connect my razr gsm v3 to the laptop?.where did i get razr gsm v3(r374 usb modem) driver?.
Do quick google search for "razr tethering" you will also need the USB cable for your phone.
May 01, 2009 | Cell Phones
Phone won't charge
you can try a new battery
Dec 28, 2008 | Motorola Mobility RAZR V3
Razr V3- Screen blank
http://www.fixya.com/support/t254165-cell_phone_screen_dont_work_help
Jun 08, 2008 | Motorola Mobility RAZR V3
PHONE ON THE BLINK
remove the battery,
hold down the * and the # key simultaneously then whilst holding it in, insert the batter, n press power on, give me the info u see on the screen ill tell u what to do
Mar 13, 2008 | Motorola Mobility RAZR V3
Broken backlight
if you open the v3 phone flip...you shall see 4 rubbers...remove the rubbers with a very small flat bit screw driver then unscrew the 4 screws in the phone then use the small flat bit onc more to open the phone cover, then remove the silver button on each side of the phone, unclip the cable leading to the camera and also the clip connecting to the lcd once those are removed then replace the old screen with the new one.
Dec 22, 2007 | Motorola Mobility RAZR V3
Bootloader USB INIT
this happens to phones that have had water damage or something else and a way that might make it work is to take the battery out for no more than 60 seconds and put it back in and push the *,# and power buttons at the same time and if the blue screen comes up, while on the screen push the buttons and hold them until it goes normal. it worked for me
Oct 01, 2007 | Motorola Mobility RAZR V3
USB Cable and charging problems
Try checking the usb cable. Some usb cables aren't made so you can charge your phone. Believe it or not but usually the cheaper cables are the ones that work for charging my motorola razr v3 phone. If that doesn't work, check to see if you didn't mess up the interface when you plugged into the phone.
Dec 08, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
