Question about LG Flatron Ez T710BH 17" CRT Monitor
Monitor repair my computer monitor is very dim even when i adjust the brightness and contrast to maximum. i tried pulling out the flyback cap to monitor just to check if there is an arcking of high voltage but i observed that high voltage is not enough and then all transistors near the flyback are good. please help me.
  • 26 Answers
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level. Just an note on the above - Begare - there are lethal voltages near the flyback transformer. you could get killed if you are not familiar with the insides of a TV-Monitor.
Posted on Jun 19, 2007
  • Ioannis Makris Jun 19, 2007
    most monitors describe the voltages expected at the secondary of power supply transformer - set of diodes. If an electrolytic capacitor went dry, small chance that could be the problem.
    Genius:
  • 1,074 Answers
The neck board of the monitor needs tube replace it is corroded with carbon if you cannot get a replacementbuy a new monitor.but also check the flyback also it could be faulty replace it check www.dalbani.com for your monitor parts or repairworld.com,good luck.
Posted on Apr 26, 2007
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
19 inch lcd monitor has dimmed display
tried to adjust in the screen set up menu the brightness and contrast. if can not get with adjustment with very dim display replaced the back light ( cold cathode lamp).
Jul 22, 2012 | Computers & Internet
Dim display problem
Have you tried adjusting the LCD's bright and contrast using the buttons on the monitor. Instructions can be found on page 12 of this manual:
https://computinghardware.web.cern.ch/ComputingHardware/doc/Samsung/SyncMaster740B/SyncMaster740B-940T-E.pdf
If the lcd monitor is dim even upon booting up, then the backlights of the lcd itself is starting to fail and it needs to be replaced.
Please let me know if you need further assistance. Thank you for using FixYa. Merry Christmas!
Dec 25, 2010 | Samsung SyncMaster 540N 15" LCD Monitor
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Feb 26, 2009 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Brightness problem
try changing all electrolytic caps in the horizontal circuits
Aug 28, 2008 | Boundless Technology Tatung VM 9AF 9" CRT...
Dark image
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
LG Flatron Ez T710BH 17" CRT Monitor Logo
320 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
