Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears Craftsman 1/2Hp Garage Door Opener - Opens on its own
Brand new 315Mhz garage door opener opens and closes on its own. Noticed that this happens primarily in colder weather (< 10 degrees F). Caught the door opening and closing at 5AM which was very unsettling. Couple other times we caught it running on its own as well, not just once, but repeating its opening and closing cycle.
Deduced it was not related to any neighbors remote, or even any of ours. Figure it must be the circuit board and have to call Sears to either get the CB replaced or the whole unit. Kind of a security issue.
  • 3 more comments
  • Debbie
    Debbie Dec 30, 2008
    I'm pretty sure ours is a Sears as well. It'll open on its own, which is unnerving enough but when we use an opener (either wall or remote) it will only open about 8 inches (frustrating!). I discovered I can get it up all the way by helping it along. It only started about 3 weeks ago when it started getting really cold. I put the vacation lock on but that's useless...it still seems to be possessed and opens at random times overnight or early in the morning.
  • danny2312 Jan 03, 2009
    I have the same problem. My door will open and close on its own. I have to pull the release cord every night and lock it manually for security reasons. No one at Sears can help me.
  • Anonymous Jan 25, 2009
    I installed a Chamberlain 1/2 HP screw drive opener in Oct 2008. We've had 4 instances (so far) since then where the door opens on its own, overnight. These all happened in December & January, so perhaps the cold does play a part.
  • wlois1 Jan 26, 2009
    I had Sears maintenance come out and look into the problem. They replaced the circuit board in the opener itself, however, it did not solve the problem as the door has now opened itself twice since they "fixed" the problem. Both times in cold weather. I now suspect this problem to be related to the wall unit circuit board having a short. Since at times when it acts up, the green light on the wall control is not lit as it should be.
  • tractorgy Mar 12, 2009
    We installed a new door opener model 139.53985DM, 315mhz, a few days ago. During a cold snap thr door opened and closed several times
    by itself. Sears repair people are due here in couple of days. I'll tell
    them the new circut board may not work. If they something different,
    I'll post that
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 98 Answers
There are three causes for this problem:
1. a remote is sticking or is getting bumped (if the vacation lock is on and it still has phantom operation remotes are not the issue).
2. the logic board could be going bad (if you have the 315Mhz you have a newer operator so this is probably not your issue)
3. the wires to the wall button have a short. Try disconnecting the wall button wires from the operator. If this stopps the phantom operaton you might solve your issue by running new wires to your wall button.
Posted on Jan 03, 2009
I also had this problem numerous times during cold weather and have solved the issue. The problem is the result of a poor mechanical design with the in garage open/close button on the remote control unit. The remote control unit utilizes two momentary contact switches mounted to the printed circuit board with a black plastic piece that is supposed to slide in relative to the control unit when pressed. The black plastic piece is then supposed to slide back out after it is released. This motion is supposed to be driven by two cantilever springs that are part of the main housing. Because the red plastic housing is not stiff enough and because the printed circuit board's location is not precisely controlled relative to the housing, the black plastic piece can become slightly wedged and not fully slide back out. Due to thermal expansion/contraction issues, the wedged black piece can then make contact with the switches as the temperature changes. To fix the problem, I removed the black plastic piece, cut off the two plastic bars that are supposed to make contact with the contact switches and wired an external switch to the unit that I now use to open and close the garage door. I then cut off the two black bars that were used to contact the switches on the printed circuit board and reinstalled the disabled black piece. Since I have made this modification, the problem has been resolved!
Posted on Sep 05, 2012
I have a problem with the door monitor for my Craftsman 1/2 HP 315MHz garage door opener. I recently had my garage door changed and now the monitor indicates the door is open when it is closed and closed...
It sounds like the sensor on the top section of the door may be mounted upside down. If you can, remount it right side up, and see if that corrects if the problem. If not, contact me directly.
Sep 11, 2013 | Chamberlain Sears Craftsman Liftmaster...
I have a new Sears 315mhz garage door opener and the door fails to reverse when an object is placed under the door
It sounds like the force adjustment may be set too high. Check this:
The force adjustments control the pressure used to open and close the door. A new garage door opener from the factory is set to the lowest possible force adjustment. If you have a properly balanced door, the forces required to open and close the door should be minimal.
The force adjustments are usually located on the rear of the garage door opener and/or under one of the light lenses, If your opener has two lights. If you have lights on the side of your opener, the force adjustment will be located under the right light lens. The force adjustments are labeled with an arrow indicating open or close and numbered 1 to 9, with one being the lowest force and nine the highest. The force adjustments can only turn 260 degrees, or ¾ of a complete turn. Changes to the forces should be done in 10-degree increments. Please remember that too much force will interfere with the proper operation of the safety reversal system. Do not increase the force beyond the minimum required to close the door. Do not use the force adjustments to compensate for a sticking, binding, or unbalanced door.
Mar 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
I installed a model hd900d garage door opener and added openers clicker model klik1u because i have a stanley old opener i was told i needed this model clicker because i have a purple learn button on the...
My best advise to you is get the brand name remote for your opener. I know it sounds like a pain but click brands are not super great because there supposed to work for many different kinda. For the most part you can call your local garage door dealer and pick one up for your opener. They may sell you a lift master brand opener which is find sears/liftmaster/chamberlain are all the same. Should only be about 35 bucks if you pick it up
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,938 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
