Removing Your TV from Shop Mode or Store Demo Mode
First, confirm your TV is in Shop Mode or Store Demo Mode:
1. Press the INFO button on your remote control. A list of settings appears. 2. See if the Picture Mode setting is set to Shop Mode or Store Demo Mode.
There are three methods for removing your TV from Shop Mode or Store Demo Mode. If the first method does not work, try the second or third method. Method 1
To remove your TV from Shop Mode or Store Demo Mode, follow these steps:
1. Press the Volume button on the side panel of your TV. If your TV does not have a side panel, press the Volume button on the front panel. The TV displays the volume bar. 2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Note: You may want to press the INFO button on your remote again to confirm you TV is no longer in Shop Mode or Store Demo Mode.
Method 2
1. Press the Volume button on your remote. The TV displays the volume bar. 2. Press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Method 3
1. Press and hold the Volume button on your TV. The TV displays the volume bar. 2. As you are holding the Volume button, press the Menu button on the side panel of your TV for about seven seconds. Again, if your TV does not have a side panel, press the Menu button on the front panel. If Dynamic or Dynamic Mode is displayed on the screen, your TV has been removed from Shop Mode or Store Demo Mode.
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Your TV is responding as if the Game button was pressed on the original remote. The additional stuff on the screen is to let you set the best brightness and other settings for video gaming. These screens should disappear on their own in 10 seconds if no buttons are pressed on the remote. See the manual http://www.symphonic.us/support/manuals.aspx and fill in the model number. If the remote were still controlling the TV, the CH up and down buttons would let you choose the Picture settings to change and volume up and down buttons would change the setting.
The TV/VCR button on the universal remote may be swapping the remote to control the VCR only. (Thus losing the ability to control the TV.) (What does the manual say about the button for the universal remote?) You may want to consider a different universal remote - programmable or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=ST419E&uuid=12844254442790 which has an exact substitute.
Check your cables for the sound issue (try new ones) and make sure that they are fully seated in the jacks.
Well your Philips universal remote control comes with a list of codes for devices by brand name. Find the first code for the brand name and type of device you wish to program. Turn all of your devices off, and then manually turn on the device you want to program. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid. Release the Setup button. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV.Release it immediately and make sure the indicator light is illuminated. Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button. If the device responds, you have successfully programmed your Philips universal remote. If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
If your TV code is not listed on the manual then you can use the Remote Using Code Search Option - Your Philips universal remote has a built-in code search feature that will find the correct code for your device. This process may take longer than using direct code entry, but can be helpful if you do not have access to the code list or if the brand for your device is not listed.
Make sure all of your devices are turned off, and then manually turn on the first device. Press the Code Search button and hold it down until the red indicator light stays illuminated. Press the Mode button for the type of device you want to program on your Philips universal remote, such as the TV button. Release it immediately and make sure the indicator light is illuminated. Press either the Channel button until the device responds. You may have to press the button up to 300 times. Each time you press the button, the Philips universal remote tries a new code. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
I thing you wrongly do the second option that creates the problem. No issue, if your tv code not listed on the manuals then you can go with the second (code search) solution. Please post comments for further help or information.........
before you try to change the channels, firts look for a button that says tv/video `press it ( some times more than once ) depending on how manny video jacks on your tv until it shows tv again, good luck
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
On the TV itself, press the MENU button. When the menu opens, "PICTURE" should be highlighted in pink and the rest of the menu items will be an aqua color. That means you are in the right place....Press the volume "up" button... this will open up the Picture menu items. When the menu opens, start pressing the channel "up" button. You will see (bright, color, etc.) options in this menu. Keep pressing the channel up button until you see "Game Mode"... the options will be ON and OFF. Use the volume "up" and/or "down" buttons to toggle back and forth between ON and OFF... if you want to watch TV, be sure to turn the Game Mode OFF... otherwise the picture will be VERY dark...
