Question about Sony KP-51HW40 51" Rear Projection Television
No power-Will not power up with the remote or power button
I checked the fuse and it is good on the G board and it is good(F6001).Is there a way to check the power supply?I have a little bit of experience using a test meter,so any help would be great.The tv was given to me as a no power up so dont know anything else about it.I had it apart(as far as the panels and all,but dont see anything like lightning damage or sort.It is a very clean tv.If I have to get premium support let me know.I would really like to get this tv working again.
  • hannadee2004 Jan 30, 2009
    if your tv is plug into a power strip unplug it wait 2 mins then plug it into a wall outlet it should work
    unplug from power strip wait 2 Min's plug into wall outlet it should work after that
    Problem Solver:
  • 3 Answers
Unplug from power strip wait 2 mins then plug into wall outlet
Posted on Jan 30, 2009
Why doesn't it turn on?
Could be power supply failure
Apr 11, 2016 | Televison & Video
Pioneer plasma pro 930hd tv no power
if the power board looks good my guess it is the main ic that is broken
Nov 22, 2017 | Pioneer PRO-930HD 43 in. Plasma Television
Craig 19 inch lcd tv shut off and i can't turn on with remote or button on tv
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_10_50_35_pm.jpg
open set and look for caps like these that are puffed up on the power supply board(follow power cord to it).
Apr 10, 2012 | Televison & Video
I have one Samsung HP-R4252 no give video and sound, I check all fuse it's good, check all voltage are good, only turn on the led in power button and flashing when press any key in the remote control, I...
try replaced main Y assy board or power supply board
Manufacturer Samsung Part Number BN96-02033A Description ASSY PDP P-Y MAIN BOARD
Manufacturer Samsung Part Number BN96-02213B Description ASSY PCB P-SMPS
Sep 03, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
The TV will not turn in (by remote or from the tv)
Is the standby LED light off ? Do you hear clicking sounds when you press the power button on the TV ?
If not it's probably the power supply board. Look at the fuses(s) on the power supply board. If the fuses are good you may have to replace the board if bad.
Mar 13, 2009 | Hisense TL1700 17 in. LCD Television
Sony FD Trinitron WEGA KV-34HS510 34" TV won't turn on. Standby light blinks 7 times
  • Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty. Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board). This may help !!
Feb 20, 2009 | Sony FD Trinitron WEGA KV-34HS510 34" TV
What is the part # for the thermal fuse?
Fuse is located on the G board. (board part no : A-1316-566-A)
Here you can download service manual and part list.
See part list.Fuse and fuse clips are F6001 and FH6001, pn 1-576-193-11
Here you can find replacements, if you do not find your model in list call them at 1-866-925-PART (7278)
Here instead you can get parts directly from Sony.
Always unplug power one hour or more before working on your TV.
If you have not worked on TVs before call a technician.
Sep 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51hw40 -No power
check all the fuses especially the pico fuses on the D board as the led should at least light up if the fusese are all good, then the set should throw an error code when you try powering it up. Let me know if you need more assistance
May 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Blinking LED light and set will not turn on.
blown capacitors on the inverter/vga board replace them and you should be good.
Apr 27, 2008 | Polaroid FLM-3732 Television
Toshiba TV won't turn power on, while plugged on. I don't see flashing lights, or hear any kind of sound while trying to turn it on via remote, or on/off button.
check fuse inside set. if fuse is good. inspect board for damage.
if good try replacing your main regulator.
need more info
Apr 09, 2008 | Televison & Video
Sony KP-51HW40 51" Rear Projection Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
