Question about Toshiba Satellite Pro L300 Notebook
Touchpad Hey, when I used Ubuntu on my laptop I had a scrolling function on the right of my touchpad so I could just take my finger up or down on the pad and it scrolled, but this function disappeared when installing Windows Vista. Is it possible to get it back?
    Sergeant:
  • 279 Answers
Go to the Toshiba website and download updated Vista drivers for your touchpad, and you should be fine.
Posted on Dec 28, 2008
Unlock scroll key
Toshiba laptop computers use multi-function touchpads, which often have software features added to the touchpad manufacturer's basic package. If your Toshiba laptop's touchpad won't scroll but its other functions are working, you may simply need to adjust your settings. If the problem occurs suddenly, try restarting your computer before resorting to other methods. Sometimes the addition of new software or other features can interfere temporarily with the touchpad driver, interrupting the scrolling feature. If a simple restart does not restore your touchpad's scrolling feature, check its properties through the control panel. The exact options for doing so will vary by laptop model and operating system.
Click "Start," then "Control Panel." Navigate to "Mouse," which may be under "Hardware and sound" or a similar category, depending on your operating system. Select the "Touchpad" tab in the "Mouse" window. This tab will also list the touchpad manufacturer, most often Synaptics on Toshiba computers. If you have more than one built-in pointing device, as is the case with the touchscreen model Toshiba Portege series, choose the "Hardware" tab and select your touchpad, then click "Settings." Select "Properties," "Settings," "Advanced" or the similar option on your system. Click the box next to "Enable scrolling" if this option is available. For Synaptics touchpads, you may have a list of options; click the arrow to the right of "Scrolling" to open the scrolling list and select one-finger or two-finger scrolling to access the specific features. Click to enable any scrolling features you desire, then select "Adjust scrolling region" or the similar option, if available. Drag the scrolling region to cover a larger portion of the touchpad if you want to ensure you can scroll easily. Click "Ok" to apply any changes and close the options windows. Keep clicking "Ok" until all of the windows with this option are closed. Restart your computer if prompted. Your scrolling feature should be enabled.
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manuaserguides-su1083054-SatM50M55PMAD0004401105May05pdf&sliceId=pdfPage_171&dialogID=79031610&stateId=0%200%20
Feb 18, 2013 | Toshiba Satellite L305D-S5895 Notebook
Scroll bar
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
Feb 03, 2013 | Acer Aspire Computers & Internet
Touchpad must be continually tapped to make scroll bar scroll up or down
Different laptop uses different type of touch pads. If your's an old laptop, that may not have a scroll function by simply sliding your finger through the right edge(top to bottom and vise versa) to scroll to a desired level. A new laptop has all these functions. Go to the control panel click on classic view in the left pane in case of xp and vista. Then you can see the mouse icon.click on it and select the device setting tab. then click on setting and a new window will open.There click on scrolling and click on one finger scrolling you can see the scrolling properties. tick mark the vertical and horizontal scrolling boxes. click apply then ok and close all the way. Thats it All done. Hope it helps
Dec 02, 2012 | Computers & Internet
How do i turn on the scrolling on my acer laptop
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again
May 13, 2012 | Acer Aspire 5100 Notebook
The touchpad doesnt work
Hi integrity078...
Try this solution to your problem
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Please take time to rate me thumbs up
Sep 18, 2011 | Acer Aspire 5100 Notebook
Touch pad scroll gestures very intermittent.works then doesnt
Hi tommymul6...
Note: Mac computers use "F2" to enable and disable the touchpad.
Sep 04, 2011 | Computers & Internet
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
Mouse doesn't scroll when you run your finger down the right side
http://www.umpcgeek.com/2008/09/acer-aspire-one-touchpad-evaluation/
Here is great article on your touchpad, probably just have to do some configuring, open a your touch pad utility in control panel, have a look at your scrolling settings.
my asus eeepc i use two fingers to active my scroll
Nov 09, 2009 | Acer Aspire One PC Notebook
Scroll function on my Toshiba Satellite TouchPad isn't working
I would go to this link and select your device and download the driver/software for your device. Try to reinstall the driver/software.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download&cm_sp=Sitemap-_-Support-_-DriversDownloads
Note:
Fn-F9 is a hot key combination that will enable/disable the touchpad.
Feb 14, 2009 | Toshiba Satellite Pro P300 Notebook
Toshiba Satellite Pro L300 Notebook Logo
224 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
