Question about Philips GOGEAR SA6045 MP3 Player
Gogear mp3 hello I have an phillips gogear mp3 charged it and was playing ok until I decided to erase all the music it had and download different music and now everthing is frozen. when I turn it on it stay on the words phillips, when I coneect it to the computer it tells me that the phillips divse manger is not on and it is. cause it show that it is installed
  • 8,596 Answers
Run the Update tab in the Philips Device Manager - make sure you are connected to the internet before performing the Update.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How do I download songs onto my phillips gogear cam
  • Charge your Philips GoGear ViBE for at least three hours before turning it on.
  • 2 Insert the small end of your mini USB cable into your GoGear ViBE. Insert the other end of this cable into one of your computer's USB ports. Turn your GoGear ViBE on by pressing and holding the "Power" button for two seconds.
  • 3 Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
  • 4 Open "Computer" from the "Start" menu and locate the GoViBE icon to make sure it has been successfully connected to your computer.
  • 5 Navigate to your music files. If you're unsure about their location, start by looking in the "Music" folder under the "Start" menu.
  • 6 Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
  • 7 Right-click the USB icon with the green arrow, located in your taskbar, to disconnect your device. Click "Safely Remove hardware," then wait until your computer confirms that it's safe to remove the device. Disconnect the USB cable from both your computer and your GoGear ViBE.
  • 8 Select the musical note icon from the main menu of your GoGear ViBE to open your music files. Navigate to the sub-folders section, and select a song from either the artist, album, track list or genre. Press the "Play/Pause" button to begin playing a song
Oct 07, 2011 | Philips GOGEAR SA6045 MP3 Player
I have a Phillips Vibe, the music already on the MP3 works fine, but I cant download a CD onto it, or should I say I can, but when I try to play it my MP3 says DRM license required!
Use a different program to download cd's with like itunes, or winamp. they just pull the music from those folders to where you want them.
www.itunes.com
www.winamp.com make sure to get the free version
Feb 16, 2011 | Philips GOGEAR SA6045 MP3 Player
How do i download songs from my pc to my phillips gogear?
The MP3 player can only play music files that are in mp3 file format.
Music on CDs need to be converted to mp3 format for your GoGear. Please click on this link and follow my instructions to convert and copy music files to your player :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Sep 20, 2010 | Philips GoGear SA3020/37 MP3 Player
I have a Phillips 4gb mp3 player. I downloaded some music to my player and when I went to listen to those songs I couldn't. I picked one of the songs and would play another song. It shows it playing on the...
Hello :
Reset your mp3 player first . If that didn't solve the problem , then I would recommend you to format your player . But before formatting you need to back up everything on it .
good luck .
please rate !
Apr 01, 2010 | Philips GoGear Flash MP3 Player
I have a phillips mp3 gogear 1.8 that i synchronized music onto and it doesn't play. my sister gave it to me without instructions
An overview of all GoGear 1.8 display media players can be found here:
http://www.search.philips.com/search/search?h=all&o=support&l=global&s=all&q=GoGear+1.8
Select your player from the list.
Updates, FAQ's, Manuals, Software and Drivers will be available for download.
Feb 16, 2010 | Philips Audio Players & Recorders
Phillips gogear play downloads songs but doesnt downloaded song
in philips go gear device it wont show the song or video unless or untill its a compatible one(e.g it wont play real player .flv files) to the player..check whether you can play the song from the device in your computer. if yes try a different youtube converter software.
May 24, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips gogear sa6185
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 24, 2008 | Philips GoGear HDD075/17 MP3 Player
player says i should not connect and then that detachment is ok.
Oct 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Charging
Double-check the software version of the new one and compare with the version on Philips website at www.usasupport.philips.com
Jan 03, 2008 | Philips GOGEAR SA6045 MP3 Player
How to erase music off phillips sa3104 mp3 player
Open windows media player, pick music, pick phillips go gear, displays music, click on music, choose delete
Jan 03, 2008 | Philips GoGear HDD075/17 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
129 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
