Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
Channel Locked I have a sony projection television and I am not able to change the channel. It keep giving me the message "channel locked on 3". I do not have th remote to the television anymore does anyone know how I can get this fixed?
    Genius:
  • 1,074 Answers
Someone have entered a code in the tv ask any member of your family who had tampered with the tv and if they had, do they remember the code they put in.if no one can give account of what had happen you will have to call a tech and have them reset your tv.good luck.
Posted on Apr 26, 2007
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
Tv goes to another channel on its own
Sounds like channel 3 is not locked in. Go to menu and select add/delet channels And add 03.
Jan 18, 2009 | Mitsubishi VS-60703 60" Rear Projection...
CHANNEL ERASED
go to menu atuoprogramming will automatically lock in every channel that you receive a signal from.
Dec 11, 2008 | Televison & Video
Channel locked
MOST TV'S MANUFACTORS HAVE A MASTER RESET-- I SUGGEST GOING ON LINE TO MITSUBISHI AND DO THE " CONTACT US" THING---MAY POST A PHONE # FOR CUSTOMER SERVICE--TUNICA
Oct 12, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Turn off channel caption on Sony 48 inch
There should be an option in the menue for closed caption set it to off.
Jul 28, 2008 | Sony KP-51HW40 51" Rear Projection...
Front buttens locked and no remote rca d52w19byx1 itc222
when using your remote once you get to where you want to Go to adjust press channel up & down buttons this will let you scroll up and down and then use vol- vol+ to make adjustments.use buttons on front of tv.ThankYou for using FixYa.Have a Nice Day.
Feb 05, 2008 | RCA D52W19 52" Rear Projection Television
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
REMOTE LOCKED
On most television remotes, there are buttons to control other units. If these buttons are hit by accident, then the remote acts like you described. Look at the top of the remote and find the button that says TV. Push it and it should start working normal. Since I'm not at my shop, I don't know the exact button or names. If this doesn't work, respond to this post and I will reply when I have a schematic in front of me.
Aug 05, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
