Question about Aloha Housewares (93645) Ceiling Fan
Uc7051r remote control
I have this hampton bay celing fan and my problem is the remote control I checked the reciver and works fine I take a part the remote and I found out that the grey pad it's not making good contact with electrical panel.
I been loking for a new remote or both reciver and remote but I can't find it does anybody knowa where can I buy a new remote
I do I have to replace the fan
5 Suggested Answers
Crossedwires
  • 44 Answers
SOURCE: Bad Receiver for remote UC7051R
I don't know if this will help you or not. but this is the site for most off brand equipment handled by target and wal-mart stores. Aloha is a brand handled by target and home depot (I think) anyway here it is, hope it helps...
http://www.alcosupport.com/
Posted on Feb 09, 2008
  • 37 Answers
SOURCE: Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Posted on Jan 24, 2009
  • 2976 Answers
SOURCE: need to change glass globe in hampton bay fan
Loosen the 3 screws around the outside of where the globe fits in.
Posted on Jan 25, 2009
Mike258
  • 1498 Answers
SOURCE: Hampton bay celing problem. the fan turns on and
Hey there,
Two things:
Try the dimmer option (if available)
Get a chair, place it under the fan, stand on it, get the remote right up next to the antenna and try it.
If it functions at close range (Like mine) I'd exchange the remote package (fan and hand helds)
If not, recheck the internal wiring. They do a nice job telling you what goes where. There are supposed to be a few loose ends also. (The onboard switches)
Best regards Mike
Posted on Apr 16, 2010
  • 351 Answers
SOURCE: I have the Hampton Bay 5-Light Track Lighting
Skill, patience, preseverance, and experience. You ned to cut and strip the wires so they "just fit" into the space provided leading to the connectyion screws. no room for stuffing , and no extra wiggle room for and bends or kinks .. You mightb try mounting the wires and then pushing the extra wire back up intio the ceiling junction box, thats what I do.
Posted on May 10, 2010
Hampton bay celing problem. the fan turns on and off. The light will not turn off with the remote or the light switch. We have changed batteries in the remote control .
Hey there,
Two things:
Best regards Mike
Apr 16, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Where is a Hampton bay repair center in Mich. I need a the part hangs the celing fan to the Elc box.
Hampton bay is owned by home depot and to the best of my knowledge there are no repair centers for hampton bay fans. That bracket can be purchased (or ordered) from home depot. You could try searching "king of fans" online, they manufacture hampton bay fans for home depot.
Aug 10, 2009 | Dryers
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
Instalation tips, no manual with used fan
Hi, The bracket is like a cup with the downrod fitting into in with a ball and socket type arrangement. When the downrod ball is in the socket there is enough room to slide the receiver in, fold the antenna over the receiver when you put it in. It does not need to stick out. The whole thing is covered with the bracket cover and nothing shows. Good Luck, this should Fixya!
Mar 25, 2009 | Universal Remote Control Hampton Bay...
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay remote for ceiling fan caused an electrical fire
We just installed this fan and within 1 day the electrical wires in the receiver burned and would have caught fire had it not been caught!!!
Jan 07, 2009 | Universal Remote Control Hampton Bay...
The replacement remote will work fine. All you have to watch out for is that the remote receiver and the remote transmitter are a matched set.
Jul 21, 2008 | Universal Remote Control Hampton Bay...
Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Aug 25, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Fan won't go on
It's probably the electronics inside the fan. They may need replacing. http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Jun 27, 2007 | Hampton Bay 04078 Avanti Ceiling Fan
Aloha Housewares (93645) Ceiling Fan Logo
571 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Mike Carew
Fan Fair Of Boca
Fan Fair Of Boca
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
