Question about HP PSC 2110 All-In-One InkJet Printer
Says printer cartridge access door open when closed
I just bought this printer scanner copier at a rummage sale and when i plug it in it say door open. close print cartridge access door. There is no print cartridges in it so would that be why it is saying that? I dont want to go spend alot of money on cartridges if thats not going to fix problem. Please help
  • Anonymous Mar 14, 2014
    left ides is off and will not again so that the access door will close
  • Anonymous Mar 28, 2014
    close cartridge access door
    Problem Solver:
  • 6 Answers
No it will not complain for an open door if there is no cartridge. There will be a separate warning for no cartridge or toner not installed error. You might want to play around with the cartridge door a little and see for a possible paper stuck somewhere inside.
Posted on Jul 27, 2007
How do u remove old cartridge from printer
  • Turn on your HP Photosmart printer if it is not already on.
  • Reach under the access door handle at the front of the printer beneath the scanner and lift up on the scanner and door until the assembly locks into an open position, revealing the print carriage on the right side of the printer. If replacing a used cartridge, push down on the label of the cartridge to unlock it from the carriage and then lift it out of its slot.
  • Remove the new ink cartridge from its packaging--holding the cartridge by its plastic sides. Pull the pink tab covering the copper-colored contacts gently down and then remove the tape from the ink nozzles.
  • Align the cartridge at the front of the slot in the print carriage with the label on the cartridge pointing up. Push the cartridge into the slot until it clicks securely in place.
  • Close the access door by lowering it and the scanner back into position.
  • Mar 02, 2011 | HP PhotoSmart 7760 InkJet Printer
    How do I change the ink cartridge
    Make sure the printer is on. Lift the scanner unit to access the cartridge area. The print cartridge carrier moves to the center and stops at the loading position. Grasp the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges and install the new ones. Snap the lids closed and lower the scanner unit to close.
    Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
    Hope this helps. Thanks.
    Nov 22, 2010 | Lexmark X1240 All-In-One InkJet Printer
    Lexmark X1150 - how do I change ink cartridge
    Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center at the loading position. Squeeze the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges. (refer to sample image below. printer shown may not look like your printer, however, the steps are the same.)
    Insert new cartridges. Color cartridge should be in the left carrier and the black in the right carrier. Snap the lid closed. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
    Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
    Thanks.
    Nov 18, 2010 | Lexmark C533DN InkJet Printer
    Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
    Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
    Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
    Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
    Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
    Ipls guide me for changing the catridge
  • Turn the printer on and confirm that there is paper in the tray. After the new ink cartridges are loaded, the printer will need to run an alignment test. On the front of the printer, above and to the right of the paper tray, there is an access door that swings open sideways. Open the access door. The ink cartridges will move so that they can be reached through the door.
  • Press both print cartridges down until they pop out of their holders. If you will have difficulty remembering each cartridge's position, remove only one at a time. Once a cartridge is popped out of its holder, it can be lifted freely through the access door.
  • Prepare the new ink cartridges for installation by removing them from the packaging and removing the tape from the bottom of each cartridge. Be careful not to touch the delicate metal contacts on the bottom of the cartridges.
  • Install the cartridges by aligning them slightly below the holders, then pushing them up and forward until they snap into place. Close the access door when you are finished. A test sheet will begin printing to check the alignment of the cartridges.
  • Open the lid of the scanner and place the test page face down on the scanner bed. The upper-left corner of the test page should line up with the arrow in the corner of the scanner bed.
  • Push the "Scan" button on the printer control panel. The scanner will scan the test page into the printer's memory, which will then be used to make any alignment adjustments that are necessary. The printer is ready to use when the test is complete
  • Oct 30, 2010 | HP DeskJet F4280 All In One Printer InkJet
    I would like to know how to install the cartridges for the x2650?
    Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center for the loading position.
    Press down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
    Oct 25, 2010 | Lexmark X2650 All-In-One InkJet Printer
    My pictures are all printing with a purple look, such as water, clothes, sky, etc... There is no other color hue, besides purple in the picture.
    Issue on kodak AiO printer not printing correctly you need to contact kodak support line at 1 800 421 6699 for printhead replacement.
    Step that you can try
    1. Clean Printhead twice press Copy button and Cancel button at the same time for atleast 10sec or until the printer move. Note cleaning printhead will consume your ink.
    2. Reseat Printhead open the printer access door remove the ink cartridges and the printhead then close the printer access door wait until red light flash on the printer open the printer access door insert back the printhead then ink cartridges
    3. Replace printhead contact kodak support
    Nov 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Paper jam?
    Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
    • Verify that the print cartridge door is closed.
    • The print carriage may be jammed, follow these steps to correct the problem:
      1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
      2. Disconnect the power cord from the all-in-one.
      3. Remove both print cartridges.
      4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
      5. Close the print cartridge access door.
      6. Plug the power cord back in.
      7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
      8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
    • Try to make a copy. If the all-in-one pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism. Contact HP for assistance.
    Nov 01, 2007 | HP PSC 1410 All-In-One InkJet Printer
    HP PSC 2110 All-In-One InkJet Printer Logo
    510 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
