Question about Whirlpool LER4600 Electric Dryer
Dryer not heating
I have a Whirlpool LER3624PQ and it'll turn on but there is no heat. I checked to make sure there was not a clog in the exhaust and all is clear. I took the back off to look at the fuses, I have no clue what is what back there and do not have a manual. Any guidance would be great!
    Genius:
  • 2,920 Answers
It could be your limit switches or your heating element gone bacd if you dont have heat. those are the only 2 options
Posted on Dec 28, 2008
Whirlpool dryer times jump on high temp from 50 to 29 takes three cycles to dry cloths.
Check that the heating element is working. Then check the exhaust flue of dryer to make sure that it is not clogged. If it is the clothing will stay damp and the room housing the dryer will get hot and muggy.
Oct 27, 2016 | Whirlpool Dryers
Dryer will not get hot
how old is it? One thing i run into a lot, is that the exhaust vent may be clogged.
if that is the case, clothes tend not to dry due to lack of air circulation. And the heating element in the dryer will not kick on. That vent is typically located in the back lower panel of the dryer. And is hooked up to a vent hose. check the hose for debris (lent) remove anything you might find. also disconnect where the hose meets the dryer, and check dryer portion as well. If nothing is clogged, then you may have a bad heating element.
Apr 05, 2014 | Whirlpool Dryers
Dryer heat is intermittent
It is probably clogged in the exhaust where the lint tube connects to your wall/house. Inside the wall can get very clogged with humidity and lint creating a goo that blocks the air from escaping.
Disconnect the dryer from the wall, put on some rubber gloves and reacg up into the wall and you can pull out globs of old wet lint, coins, and other junk trapped in there. Secondly, check on the outside of your house where the exhaust is released and make sure it's not clogged there too.
Mar 26, 2012 | Whirlpool Dryers
Electric dryer not heating model Ler3624PQ
Here is a video to walk you thru the troubleshooting process.
Jan 09, 2011 | Whirlpool Dryers
WHIRLPOOL DRYER LGR7646EQ0 Super dryer model does not heat up. There is a little bit of heat coming into the dryer, however, clothes are not dried up in a 70 minute cycle.
The dryer is fine. Don't waste money on any parts. The problem is the exhaust is clogged or restricted from behind the dryer to the outside of your home. Pull dryer from wall and remove exhaust from wall. Get an electric leaf blower and stick inside wall exhaust. Push dryer back against it to hold it in place. Turn the blower on and go outside to watch every thing fly out of the exhaust. Have fun and good luck.
Jan 30, 2010 | Dryers
I have a Whirlpool gas dryer, LGR5636JQ0. It will
if the vent is clogged or duct in back of machine is will over heat and safety will shut off heat pull maching out check ducts and exhaust prt on machine
Jul 06, 2009 | Whirlpool LGR5636L Gas Dryer
HE4 propane dryer wont heat, how do I get the codes display?
Sounds like a clogged exhaust duct or vent. If not venting properly, most dryers will turn the heat off, for safety reasons.
Go for the easy fix first. Before removing your exhaust ducts from the dryer, look for any kinks that may cause blockage. Clean out the duct of any lint or water that may have accumulated. Check the vent on the outside of the house and make sure that its not clogged and opening properly.
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer runs fine, does not heat?
Remove the back and on the right side is the heater assembly. Attached to this assembly is a safety thermal fuse at the top and a heat limiter thermostat at the bottom. The fuse, thermostat or heater may have failed. The MOST common reason for any of these parts to fail is a clogged or restricted exhaust. Be sure to clean/inspect the exhaust system or the dryer will fail again.
Dec 25, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer not enough heat
There may very well be a clog in the vent line. Check the vent to be sure it is clear. Make sure to check the outside vent cover. Some of these vent have screen/louvers that can get clogged.
Jan 02, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER4600 Electric Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
