Question about GE Profile Harmony DPGT750GC Gas Dryer
Mi secadora GE Profile Harmony electrica no calienta
Mi secadora da vueltas y todo pero algunas veces si calienta pero la mayoria de las veces no, ayudeme porfavor
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer STOPS without pattern
You didn't state whether or not you were getting an error code. On this model if the blower motor exceeds 3000 rpms for one minute the dryer will stop. Usually this is caused by a clogged or pinched vent hose or vent itself. Check this out first. You can find the tech sheet under the consol. I believe it unscrews from the back and lifts up. This will give you detailed info on how to enter the diagnostic mode. If you cannot find the tech sheet, post back and the cat here will walk you through it. Catriver..post back.
Posted on Oct 24, 2006
Master_Tech
  • 770 Answers
SOURCE: GE profile Harmony electric dryer
not sure of a reset button there maybe a fuse on the controller board What is the problem you are having??
Posted on Jan 21, 2008
SOURCE: Dryer Not Heating
I have the same promblem can u email the diagram thanks
chifelicia@windstream.net
Posted on Mar 01, 2008
Master_Tech
  • 770 Answers
SOURCE: Por favor denme respuesta en Espa?ol
There is a thermal fuse on the top portion (side)of the heating element check to make sure it is not open this will not allow the unit to heat also the vent maybe clogged to the outside causing this to blow the fuse check that as well
Sorry I can read and understand Spanish but cant write it
Posted on Aug 05, 2008
dragonsthatk
  • 547 Answers
SOURCE: ge profile harmony electric dryer doesn't always heat.
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Posted on Jul 19, 2009
Elignitor le pongo corriente directa y si funciona pero conectado a la secadora no le llega corriente, si prende el motor que puede ser
It appears that one or more safety limits have failed. You will need an OHM meter to determine which one has failed.
Jan 21, 2013 | GE Profile Harmony DPGT750GC Gas Dryer
Mi secadora enciende pero no calienta
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 13, 2011 | Frigidaire GLER642A Electric Dryer
Mi secadora Whirlpool care II se oye el motor funcionando pero no gira el tambor de adentro
posiblemente sea que la correa del tambor se rompio. tambien pudiera ser que la usaron sin el filtro(lint screen) y se trago una media u otra pieza de ropa y esta atrapada en el abanico del motor o se le rompio la parte tensora de la correa. de todas formas tiene que desarmala para ver que tiene. suerte.
Feb 06, 2011 | Whirlpool Dryers
Rengo una secadora bauknecht y tiene error f21, me podeis ayudar?
A mi me acaba de ocurrir lo mismo. Simplemente la he desenchufado de la corriente, la he vuelto a enchufar... y, misterios de la tecnología, ya me ha funcionado.
Saludos
Jan 26, 2011 | Dryers
Zanussi td 4212 no calienta la recistencia esta bien lae comprobado y no esta cortada los termostatos estan bien me podeis decir donde lleva el rearme de la recistencia que no lo encuentro y si puede ser...
Hola, supongo que ya la habrás arreglado, dejo esto para futuras consultas.
La secadora tiene, ademas de los termostatos de la resistencia, un termostato de seguridad dentro del tambor, por encima de la puerta, es bastante facil de desmontar y comprobar, la mia tenía esa avería.
Suerte
Sep 09, 2010 | Zanussi TC7102W Electric Dryer
MI SECADORA NO ENCIENDE QUE PUEDO HACER? YA PROBE LA ALIMENTACION ESTA BIEN¡
chequea la conexion de entrada de la secadora es muy probable que los cables esten dañados si no es eso chequea el push on o el interuptor de la puerta que cierre contacto si no es eso chequee los sensores termicos de la secadora que si estan en mal estado no enciende
Aug 16, 2010 | Frigidaire Dryers
NO PRENDE MI SECADORA KENMORE 400
no enciende la secadora kenmore
Feb 15, 2010 | Kenmore 400 6942 Dryer
It runs and there is heat but after 1 or 2 minutes it stops
rosalinda_ta la secadora es de gas o es elecrica tambien necesito por favor el modelo y la serie adjunto con el año de la misma.
Gracias estamo aqui para ayudarte con todo gusto.
Espero tu respuesta.
your reting is important for me
Was this helpful?
May 19, 2009 | Whirlpool Dryers
Jul 21, 2008 | Whirlpool LER4634J Electric Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
244 people viewed this question
Top GE Dryers Experts
Richard Roth
Richard Roth
Melissa Martin
Melissa Martin
ancel1961
Level 1 Expert
Are you a GE Dryer Expert? Answer questions, earn points and help others
