Question about Canon PIXMA MP130 All-In-One InkJet Printer
Can't print on my pixma mp130
Message reads:the waste ink absorber is almost full see manual.
no info about this in manual, can you help?
  • Canon Master
  • 525 Answers
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit.......Done..
I hope this help!
Posted on Jan 15, 2015
This problem can only be fixed by having it serviced by repair technician.It requires the base to be removed absorber pad replaced.This a costly repair, around $90.00 & 10.00 for pad.Technician advised it would be a waste of money especialy if the machine was out of warranty. Printers are quite cheap to by new as against to fixing as in my case.
Posted on Dec 29, 2008
Waste ink absorber is almost full on my Canon Pixma MP130 will not print. How do I locate this absorber and how do I clean it ?
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Sep 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 'waste ink absorber' message
If the error message is ""ink waste absorber almost full"
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing OK
4)Enter ABS-M LEVEL by pressing <--- or ---> then OK
5)SET ABS-M LEVEL TO 0
6)OK
7)STOP/RESET"
If the error message is "" bottom ink waste absorber almost full"
Set "ABS-P" level to 0. Then "OK" and "STOP/RESET"
To clean the absorber, open the cover, and there are 2 small pads under where the cartridges normally sit. Put a pad of absorbent kitchen towel on top of the pad and press down a few times. The towel should absorb most of the ink. To give it a really good clean, turn the printer upside down while holding the kitchen towel over the pads and press a few times. You'll get more ink out.
It's a good idea to wear disposable gloves when you do this.
Apr 07, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Servicing the, waste ink absorber, on a Canon printer
You need to manually reset the waste tank counter.
Mar 24, 2008 | Computers & Internet
The waste ink disposal is almost full and it won't print
The waste ink absorber is almost full. Press [OK] to continue but early replacement recommended. <See manual>
WASTE INK NEAR FULL The printer has a built-in waste ink absorber to hold the ink used during print head cleaning, for example. This error message indicates that the waste ink absorber is nearly full.
Press the OK button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact a Canon1.gif service representative. (You will need to replace a particular part of the printer.) Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing cannot be performed until the Waste ink tank is replaced.
this answer is directly from canon
Jan 30, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Help with absorber
Someone else asked same question on this site and got answer:
http://www.fixya.com/support/t198707-ink_waste
I also had that message. This seemed to work to clear the message and let you carry on printing.
Also, I may be wrong, but the actual ink absorber is the sponge part by the rollers underneath when it prints. I dont know if it has sorted the actual problem, but I took the sponge part out (I have an MP130 and the sponge part lifts straight out if you carefully put your finger underneath it on the left hand side) and let it soak in water, sqeezing it to get the ink out (It was full of ink so careful not to get it everywhere as it can be a little messy). When it had dried, I carefully put it back in (make sure you put it in the right way around).
Hopefully that now means the ink absorber is again empty AND the error message has gone.
Not sure about the whole cleaning the sponge idea, but I did it and according to the manual that sponge is labelled as the ink absorber so technically I have emptied it?
I haven't seen any posts about actually cleaning the sponge so take that part as you will.
Dec 18, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
