Question about GE Profile Harmony DPGT750GC Gas Dryer
MI secadora no calienta
Mi secadora ge profile harmony da vueltas pero no calienta y no seca la ropa, pero de vez en cuando si calienta, que estara pasando?
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: Por favor denme respuesta en Espa?ol
There is a thermal fuse on the top portion (side)of the heating element check to make sure it is not open this will not allow the unit to heat also the vent maybe clogged to the outside causing this to blow the fuse check that as well
Sorry I can read and understand Spanish but cant write it
Posted on Aug 05, 2008
Master_Tech
  • 770 Answers
SOURCE: GE profile Harmony electric dryer
not sure of a reset button there maybe a fuse on the controller board What is the problem you are having??
Posted on Jan 21, 2008
catriver
  • 878 Answers
SOURCE: GE Profile Harmony DPGT750EC Electric Dryer STOPS without pattern
You didn't state whether or not you were getting an error code. On this model if the blower motor exceeds 3000 rpms for one minute the dryer will stop. Usually this is caused by a clogged or pinched vent hose or vent itself. Check this out first. You can find the tech sheet under the consol. I believe it unscrews from the back and lifts up. This will give you detailed info on how to enter the diagnostic mode. If you cannot find the tech sheet, post back and the cat here will walk you through it. Catriver..post back.
Posted on Oct 24, 2006
SOURCE: Dryer Not Heating
I have the same promblem can u email the diagram thanks
chifelicia@windstream.net
Posted on Mar 01, 2008
ser71
  • 818 Answers
SOURCE: hola me han regalado una camara GE minicam HO98756,
mira esto
http://www.jascoproducts.com/support/
Sergio
Posted on Apr 03, 2008
Mi secadora de gas no seca la ropa me la deja siempre mojada quisiera saber cual es el motivo
is it heating as good as you think it should . quite possibly the problem is with the washer not spinning them as dry as it is supposed to .there fore making the dryer seem the problem
Apr 07, 2015 | Kenmore 73952 Gas Dryer
Mi secadora Kenmore elite calienta pero no seca la ropa q puedo hacer
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Feb 16, 2015 | Kenmore Dryers
Elignitor le pongo corriente directa y si funciona pero conectado a la secadora no le llega corriente, si prende el motor que puede ser
It appears that one or more safety limits have failed. You will need an OHM meter to determine which one has failed.
Jan 21, 2013 | GE Profile Harmony DPGT750GC Gas Dryer
NO TENGO INSTALADO EN MI PC EL CONTROLADOR DE ETHERNET
Estas en la seccion de Secadoras de Ropa y no de Computadoras. no te podemos ayudar aqui. lo sentimos.
Feb 12, 2011 | Dryers
Mi secadora Whirlpool care II se oye el motor funcionando pero no gira el tambor de adentro
posiblemente sea que la correa del tambor se rompio. tambien pudiera ser que la usaron sin el filtro(lint screen) y se trago una media u otra pieza de ropa y esta atrapada en el abanico del motor o se le rompio la parte tensora de la correa. de todas formas tiene que desarmala para ver que tiene. suerte.
Feb 06, 2011 | Whirlpool Dryers
Zanussi td 4212 no calienta la recistencia esta bien lae comprobado y no esta cortada los termostatos estan bien me podeis decir donde lleva el rearme de la recistencia que no lo encuentro y si puede ser...
Hola, supongo que ya la habrás arreglado, dejo esto para futuras consultas.
La secadora tiene, ademas de los termostatos de la resistencia, un termostato de seguridad dentro del tambor, por encima de la puerta, es bastante facil de desmontar y comprobar, la mia tenía esa avería.
Suerte
Sep 09, 2010 | Zanussi TC7102W Electric Dryer
MI SECADORA NO ENCIENDE QUE PUEDO HACER? YA PROBE LA ALIMENTACION ESTA BIEN¡
chequea la conexion de entrada de la secadora es muy probable que los cables esten dañados si no es eso chequea el push on o el interuptor de la puerta que cierre contacto si no es eso chequee los sensores termicos de la secadora que si estan en mal estado no enciende
Aug 16, 2010 | Frigidaire Dryers
Jul 21, 2008 | Whirlpool LER4634J Electric Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
443 people viewed this question
Top GE Dryers Experts
Richard Roth
Richard Roth
Melissa Martin
Melissa Martin
ancel1961
Level 1 Expert
Are you a GE Dryer Expert? Answer questions, earn points and help others
