Question about Kenwood DDX-6019 Car DVD Player
Bypassing the parking brake safety
Is there a way to jump out or bypass the parking brake safety that will allow dvd's to be played without the brake engaged ?
  • jkozay Feb 08, 2008
    I just bought the DVD player and when I grounded the parking break wire I still only had sound and no picture. Any other ideas?
  • Anonymous Mar 01, 2008
    yup, in the same boat....
PUT THE GREEN WIRE TO THE GROUND IT ILL WORK I HAVE ONE
Posted on Apr 14, 2008
  • 14 Answers
This is illegal to do in many states so it is not recommended that you bypass the saftey feature and can result in you being ticketed and fined. On this unit, for testing purposes, you would ground the parking brake wire and the screen should come on and stay on.
Posted on May 07, 2007
Parking brake safety bypass
here is what you need to do is, get a toggle switch and hook one side to a ground and the other side to the parking brake wire on the unit.
use the switch as a brake because you have to set brake for a few seconds then release and set again but keep it on this time.
you will have to do this every time you start the car.
Jun 26, 2009 | Dual Electronics XDVDN8190 GPS Receiver
I cannot play DVDs without the parking brake engaged how do i bypass this?
I ran across of alot of lcd head units that requiers the parking brake wire connected so it will show the video, (usually just audio if parking brake not on). But if you connect that wire to a proper ground (screen always on) or a grounded switch so you can control it maually (turn it on or off when you choose)
May 30, 2009 | Pyle PLD52MU Car DVD Player
Kenwood DDX514, bypassing the parking break wire for video
Just hook up the parking brake safety switch from the unit to ground. That will do the trick. Hope this helps
May 23, 2009 | Kenwood DNX7100 Car Video Player
Dual XDVD700
How to get code for xdvd 700
Apr 28, 2008 | Jensen VM9510 Car DVD Player
Help me and my son
based on safety concerns. the DVD won't work if brakes are not engaged. The sensor for the enabled/activated brakes is the yellow/blue wire.
To bypass this model would mean grounding the brake wire would allow DVD playback. There is a little trick to make it work. It should start first as +12 before it should be grounded before the DVD will play hence a DPST switch would be required, not only grounding.
This is better explained here. Should you be in need of the manual, it is available here.
Additionally and a friendly reminder, in some regions, it is not allowed to view a DVD movie while vehicle is in motion.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Dual XDVD8181 Car Video Player
Parking brake
ground the pink wire that will allow player to play video
Feb 04, 2008 | Car Audio & Video
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Bypassing the parking brake feature
just earth the handbrake cable (light green) on a good earth point.
May 01, 2007 | JVC KD-AVX1 Car DVD Player
Kenwood DDX-6019 Car DVD Player Logo
1,367 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
