Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Washer stopped agitating and spinning
Had a large load of towels going and machine made an unusual sound. Machine will not agitate or spin now just hear the motor running. I took all towels out to see if it would run without anything in it but water, but still no movement.
  • Anonymous Mar 15, 2014
    My old commercial grade machine pump works ok, but it will not wash. Motor is running but machine is not spinning or turning. It stopped while washing towels. Took out towels and after laying machine over and upright again it started with water but no load. Once one towel was put in it would not turn. Makes a rattling noise.
  • Anonymous Mar 30, 2014
    agitator not working
  • 318 Answers
The most common problem after a large load is the motor coupling has broke. it is what connects the motor to the transmission. it is not hard to replace if you can get the cabinet off the unit. you have to take the control panel loose and "hinge" it back to get access to the clips that hold the cabinet on to the frame. once you remove the cabinet, then take off the pump clips, the motor clips and then the motor. that will allow you to get to the coupling and replace with a new one. sounds easy but its not for a first timer. good luck and hope you can find this of some help.
Posted on Dec 29, 2008
  • Carol Ann Hroch
    Carol Ann Hroch Sep 29, 2012
    thank you so much we need to find out how to remove the shell
  • Tom Zwiebel
    Tom Zwiebel Sep 30, 2012
    glad that it helped you.. if you need any other help, just message me here.
2 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Machine stopped agitating and basket does not spin.
replace coupling,,,
Posted on Dec 28, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
I had something wedge in the agitator and cause the machine to stop performing
sounds like you blew either a circuit breaker in your home or on the rear of the machine
Jul 06, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The washer quits spinning sometimes, mostly when
May have a basket drive going bad. Not a bad job but can be tedious to get to.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
WHIRLPOOL TOP LOAD WASHER MAKING GRINDING NOISE FOR AGITATION
When you put the motor in did you replace the coupler between the motor and transmission? When fixing the agitator you need to get the agitator repair kit, It has seals, dogs,thrust plate, cam bearing and seals. The upper agitator is supposed to move only in one direction to get the clothes to move down towards the agitator. Do not overload machine. I have one of these and after 12 years I finally had to install this upper repair kit because the upper agitator quit moving. You may have an agitate cam that is going bad inside the transmission
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
543 people viewed this question
Dan Webster
Dan Webster
Sal De
