Question about Olympus FE-170 Digital Camera
Date/time function My camera is an Olympus FE-170. Date/time function is no longer accurate. I tried taking the batteries out for over 36 hours, but the screen for setting time/date still does not appear. How can I make the time/date correct?
Actually, it was easy. My fault. I didn't realize I could keep scrolling through my "set-up" option - from "menu" to the date/time icon. Once I found that, I just had to work my way through it. The only thing is, it's set up as a 24 hour clock, and I would prefer it as a 12 hour AM/PM. Haven't figured out how to change that yet, but it's not serious. At least the date will be correct now.
Posted on Dec 29, 2008
Need correct day and time on Olympus FE 170 digital camera
How do I set the date and time on the FE-170?
To access the clock controls, turn the mode dial to any shooting mode except [GUIDE] and then press the [MENU] button. Next, press the Right arrow on the arrow pad to select the [Setup] icon. Using the Up or Down arrow, navigate to the menu item depicting a clock. Press the [OK] button to access the clock settings feature.
Set the year, month, day, hour, minutes and date format using the following procedure: Use the Up and Down arrows to select values, and press the Right arrow to advance to the next item. (The FE-170 uses a 24-hour clock.) When all information has been entered, press the [OK] button to set the values. Press [MENU] twice to exit the menu.
To set the time precisely, with the cursor on either "minutes" or "date format," press the [OK] button as the time signal strikes 0 seconds.
The date and time settings will be returned to the factory defaults if the camera is left without batteries for approximately three days. Custom settings may be canceled more quickly if the batteries were only loaded into the camera for a short time before being removed. Before taking important shots, check that the date and time are correct.
Oct 22, 2012 | Olympus Fe-170 6.0 Mp 3x Optical Zoom...
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at...
on rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Dec 16, 2008 | Olympus FE-170 Digital Camera
My olympus fe-170 lcd screen won't show ANY pictures.
it would appear that the lcd screen has malfunctioned and would need repair.... you can try power cycle by taking batteries out and press and hold power button down for 10 secs, draining all power out of camera, then put the batteries back in and try again
Olympus fe-170 will not switch on!
does appear to be power issue, you can try lithium AA batteries or send to repair shop
Nov 28, 2008 | Olympus FE-170 Digital Camera
LCD FOR OLYMPUS FE-170 BROKEN CAN IT BE REPAIRED
my olympus FE-170 screen won't show any picture. All other things are fine and working the screen just won't show pictures taken or a picture i'm aout to take. the camera is about 2 years old i've had no problems with it till now. Can someone pleeeaaasssse tell me their is an easy solution to this.
Nov 23, 2008 | Olympus FE-170 Digital Camera
Olympus FE 170 Digital problem
power issue... you may want to try lithium AA or send camera to repair
Sep 22, 2008 | Olympus FE-170 Digital Camera
Broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
Mar 01, 2008 | Olympus FE-170 Digital Camera
Red Flash mark while taking photo
It sounds to me like you are not waiting for the camera to charge the flash when turning the camera on or between shots. It seems you are using 1700mAh batteries and most modern digital cameras are better off using 2500mAh batteries. Your camera was released in September 2006 so it is considered "modern". With 1700mAh batteries, your flash (warm-up) recycle time time will be rather long or the amperage may not be enough to fully charge the flash unit. I highly recommend Duracell 2500mAh rechargeable batteries.
Oct 12, 2007 | Olympus FE-170 Digital Camera
Olympus fe 170
Olympus customer support This camera has a major fault and will be replaced if a year or less old- a repair prince will be like a new camera all over
Aug 07, 2007 | Olympus FE-170 Digital Camera
Olympus FE-170 Digital Camera Logo
116 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
