Question about Mustek Be@rPaw 1200CU+ Flatbed Scanner
Scanner installed software connected usb after all was installed to computer,then opened photo-impression where i installed it to, bear paw remote there yet when given first scan to do it says initialize scanner 0% and freezes.... I had not downloaded the installation book til after this then read that I wasnt supposed to have it plugged in to wall at all? How do you use direct scan? not seen in book? Also, I previosly unistalled this program but it would not clear all??? then re-installed driver to make sure it was good. If I need to re-install what parts do I need to re-install??? Crazy Woman lots of questions....anyway your help would be mucho, mucho appreciatied! Thanks in advance for any questions you can answer. If you could just get me where i can get a job to fly on this thing i can figure out the rest....its a bueaty now i want to see it work!
    Genius:
  • 2,985 Answers
What system are yo operating this scanner on? It wont work on XP.
Posted on May 28, 2007
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
How to install it in Windows Vista?
sure not hard at all. all you have to do is:
  1. Close all open programs on the computer.
  2. Locate the HP Photo & Imaging software CD-ROM that is appropriate for the language and operating system and insert the CD-ROM disk into the computer.
  3. For a Microsoft(R) Windows computer: Follow the instructions on the screen. Or, if the installation program does not start automatically:
  4. Click Start , then click Run . The Run window will open.
  5. In the Open box type: X:\SETUP.EXE (where x is the letter of the CD-ROM drive).
  6. If the instruction prompts to shut down the computer, do so.
  7. Connect the USB cable between the USB port on the scanner and the USB port on the computer.
  8. Connect the power cable between the scanner and a surge protector or a grounded wall outlet. This turns on the scanner.
  9. If necessary, turn the computer on again.
this product is no longer being supported by HP so here is a link to updated drivers if needed.
http://www.softwarepatch.com/utilities/hp-scanjet.html
hope this helps. please rate me and thanks for choosing enterprise computing solutions
Oct 07, 2009 | HP ScanJet 3500C Flatbed Scanner
Won't scan photo to computer.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
My screen comes up with the Insfficient memory
it could be ether hardware or software problem. try installing the scanner on a friends computer and see if it does the same thing. if it does then your scanner if faulty, if not then try uninstalling you scanner drivers restart your computer and go to http://www.mustek.com.tw/Download/driv_scanr/europe/b4800tapro.html
to download the new drivers to reinstall.
Aug 18, 2009 | Mustek Bear Paw 4800 TA Pro Flatbed...
Can't select OCR language in settings for Mustek 1200 UB Plus usb
the mustek pb1200 ub is the same as the packard bell bear paw 1200 try the software for that
Aug 05, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Need adapter connectfor an HP Photo Smart 35 mm slide scanner
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
Jan 16, 2009 | HP Photosmart Photo Film Scanner (35 mm)
Cannot download pictures from camera to PC
you might need to go to the manufacturers web site and download the drivers for your camera. or if your camera came with a CD isert that into the computer and install it before connecting your camera again. if that doesnt work you will need to buy a fifteen in one card reader for your memory card. that will plug right into the comuter and you will take the memory card out of your camera and put it in the card reader. then you should be prompted that something has been inserted into you computer.
Nov 06, 2008 | Sanyo VPC-E760 Digital Camera
Scanners
If you are running XP sp3 or vista use the Mustek Bear Paw 1200UC drivers they work fine!
There are also driver sfor MAC there.
http://www.mustek.com.tw/apprg/listdriver?LID=2&PRODUCTID=SFamBear1200CU
Mar 22, 2008 | Office Equipment & Supplies
Easy cam
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Aug 20, 2007 | Xirlink Promax Webcam
Mustek Be@rPaw 1200CU+ Flatbed Scanner Logo
67 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
