Question about Comet GXD2527G Pressure Washer Pump
Pump wont come off - Comet GXD2527G Pressure Washer Pump
Washer machine front loader wont fill up and wont drain
it maybe that the pump winding is open circuit some machines use the pump winding as the neutral line for the water valves so if the pump fails they wont fill no point in it filling if it wont empty
Mar 09, 2014 | Indesit W 123 Front Load Washer
96 voyager fuel pump runs but wont pump
have you checked the fuel pressure regulator on the fuel rail
Jan 27, 2013 | 1996 Plymouth Voyager
Changed fuel pump but it wont start
Check for spark, if spark then spray start fluid into throttle body, if it starts check your fuel injectors with a noid light also check crankshaft position sensor. If the pump wont pump check the fuse and connection to the fuel pump for voltage.
Apr 01, 2012 | 1995 Dodge Intrepid
Fuel pump wont stay on wont start replace the
The pump is not supposed to stay on, you should only hear it for a second or two when the ignition is turned on. At least you know the pump is working. There must be a problem in the ignition system, like no spark, do to a bad coil, ignition module, without testing it's hard to say.
Nov 10, 2009 | 1983 Dodge Pickup
Wont pump water
wont spin until drained can u hear the pump running if notpossibly somthing stuck in pump
Nov 10, 2009 | Washing Machines
94 cutlass ciere wont start
check out fuel pump relay and oil sending unit for oil leak oil sender is made to cut out fuel pump apon oil pressure failing
Jun 30, 2009 | 1994 Oldsmobile Cutlass Ciera
Wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Feb 04, 2008 | Hotpoint WMA30 Front Load Washer
Comet GXD2527G Pressure Washer Pump Logo
151 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
