Question about Gateway MT6730 Notebook PC
Gateway laptop will not power on
Lights are on but the laptop (gateway model MT6730) will not power up at all. The following lights are on:
- Blue circle light around power button
- What looks like a signal light near the scoller
- A lock with an A inside it near the scoller
- Blue light and red light on front of laptop
The lock light seems suspect to me as I have a 2 year who may have been pressing buttons. Help! We just bought this a couple months ago.
  • Anonymous May 01, 2009
    Computer was working fine until I shut it down. Now, the power & charge lights come on, the fan starts, and the hard drive and CD icons briefly light up. (Hard drive is spinning).
    That's it! No beeps, no post, no display.
    I have changed the memory, re-seated the CPU, removed the main battery & CMOS battery. Still doing the same thing.
    I suspect either the bios has become corrupted or the motherboard is bad.
    Could possibly be a bad CPU....
    Anyone know what the problem could be with this model. Seems that they all have this issue in common.
    Also, does anyone know if the bios is linked to the hard drive? I know this would be unusual but I have heard of it in the past. Maybe part of the bios info is on the hard drive and the hard drive is bad ????
    Problem Solver:
  • 22 Answers
Defective integrated video card. .harddive and other components should be fine repairs average $270.00
Posted on Jan 19, 2010
  • 30 Answers
Sounds like to me, that you do have power going to your computer(other wise your lights wouldnt be on), but that your hard drive is dead.
You can take it to a computer shop and have them replace your hard drive.
Posted on Dec 28, 2008
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Cooling fan with heatsink on my GatewaY MT6730 has stoped working. How do I replace it? It appears that I can just remove several screws and power plug and lift it out from the bottom, but it can't...
presley2001 it is that easy!! On a lot of laptops it's as easy as removing a panel and a few screws...
Please, please, please, we need to know how we aredoing! Please rate our help to you and leave us a comment so we could go onhelping people like you that need our assistance and expertise! Thank you and, Thankyou for using FIXYA! Bestregards,
Junior
Sep 19, 2011 | Gateway MT6730 Notebook PC
Gateway Mt6730 starts up and then message comes up CPU Fan Overheating and shuts down in 5 seconds. Cleaned the fan but still does this.
Try cleaning the air vents too with a can of compressed air as dust can block these vents causing the CPU to overheat. The vents can be located at the back or sides of the laptop. Also a good idea is check and make sure that the CPU fan itself is working and spinning up.
Regards.
Dec 11, 2010 | Gateway MT6730 Notebook PC
I install the windwos 7 on my gateway laptop but
if you right clik the speaker in the bottom right task bar tere should be recording tab make sure your mic is set to default
Apr 05, 2010 | Gateway MT6730 Notebook PC
My Gateway MT6730 keeps overheating and shutting off. How can I fix this problem?
your system need to be cleaned it is full of dust and not getting proper air flow cleaning the cpu fan should solve your problem
Mar 09, 2010 | Gateway MT6730 Notebook PC
Gatweway lap top button light up, but wont turn on
I'm afraid this sounds suspiciously like a motherboard problem. It would help to know what model etc, as some Gateway & EMachine model laptops have had extended warranties due to motherboard issues, or just go to Gateway.com and research it yourself.
Jul 20, 2009 | Computers & Internet
Gateway laptop battery won't charge when plugged in, new bettery
Remove the battery at once clean its contact terminals with cotton swab then reinsert it firmly, there is loose contact at battery terminals so try this again .you must get loose contact. now switch on power
Jun 06, 2009 | Gateway MT6730 Notebook PC
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Gateway MT6730 Notebook PC Logo
492 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
