Not getting ink from cartridge to paper, i believe my gap settings are messed up.
A few possibilities here: One, is your ribbon cartridge dried out (essentially out of ink)? Dot Matrix printers aren't near as common now, and if your cartridge has been in the retailer's stock for years, then it could indeed be dried out.
Another, the ribbon isn't being advanced, or spooled. The ribbon is spooled as the head carriage moves back and forth. If it isn't being spooled, the ink in the spot over the printhead will be quickly depleted. A no-spooling condition is usually caused by a problem in the cartridge itself. Also, make sure the cartridge is properly seated in the holder. If it isn't, the drive spindle isn't fitting up into the cartridge properly, and might not actually drive the mechanism inside the cartridge.
Lastly, if your cartridge is dry, they can be reinked if you can find someone with the reinker to do it. I once did ribbon reinking with a Macinker as a side business, and someone in your area might have one of those rigs. Otherwise, just buy a new cartridge, and hopefully it will be reasonably fresh, with good ink.
