Question about Sony MEX-BT2500 CD Player
Track won't advance
When I'm playing a cd it won't advance from one track to the next.
  • 2 more comments
  • justmesvaz Dec 31, 2008
    I cleaned it, still won't advance tracks.
    It starts the same track over again...I don't know how to let you know other than this way.
  • justmesvaz Jan 01, 2009
    I have tried with a number of cd's.
  • justmesvaz Jan 03, 2009
    Duh...why didn't I know that? lol
    Brigadier General:
  • 8,619 Answers
Hi! Deatach the front panel, take a ball pen and press it against a small RESET button. Now try inserting a cd.
Posted on Jan 01, 2009
    Genius:
  • 1,011 Answers
Sir,
Follow these steps.....
Step 1.Check all connections, such as from player to amplifier or receiver and receiver to speaker. Check and clean contacts on RCA jacks and cables and try a different input on the amplifier or receiver.
Step2 :Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully.
Step3 : Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function.
Step 4: Have the laser-head assembly checked by a repair person if the traverse assembly seems intact and free of debris.
Step5 : Check for a stuck CD if the drawer won't open or close or will only partially open or close. If there isn't one, have gears and belts replaced.
Step6: Lubricate the gears if the CD player will only play certain tracks or up to a particular point on a disc.
Step7: Look for broken plastic parts, such as gears and clips.
Step8: Look for loose or broken internal connections.
Step9: Have the power supply replaced if your CD player overheats.
Thanks
good luck
    Novelist:
  • 163 Answers
The player need leans alignment, because problem occurs due to some loosing in leans place.
    Genius:
  • 1,199 Answers
Try reseting the unit either take it off the car battery or unplug for five min!
    Scholar:
  • 140 Answers
Hello, It sounds like you have it in repeat mode. Look for the button that has REP or acircle with an arrow and push that button. Let us know what you find. Good luck.
Posted on Dec 31, 2008
  • David Robinson Dec 31, 2008
    It's button number 3 at the bottom of the unit. If that doe'nt work remove the head unit and push the reset button on the stereo bottom left.
    Master:
  • 479 Answers
If it stops completely after playing 1 track and you have to select again for another track and then it again plays that track and again stops then it is quite possible you have selected a option single track in the device settings. just check out in the settings and make it proper.
    President:
  • 2,110 Answers
The cd it self may have scratch..so try with another cd...
  • 10,594 Answers
Let me know, do you get error message while going to next track?
OR CD track got stuck and doesn't play any more.
Posted on Dec 28, 2008
  • Shahid Electronics
    Shahid Electronics Dec 31, 2008
    Ok, 2 things come in mind.
    Check may be you selected repeat option in control panel.
    Check may be some thing obstruct/ stops optical lens to move further on its sled mechanism.
    Here is an image of optical lens mechanism rear view. It will help you to check Sled Worm in lens mechanism.
    Genius:
  • 2,920 Answers
Have you tried cleaning the drive with a disk cleaner to see if thats the problem> it could just be dirty
  • Ronnie Houston Dec 31, 2008
    it may be time to buy a new cd player if that one still isnt working right.i dont know what else would keep it from going to the next track
  • 837 Answers
Have you tried a CD disc cleaner .. just to be sure the drive is clean
2 Suggested Answers
  • 57 Answers
SOURCE: will not advance to next track of CD..unless I do
do you have the setting set to repeat track only?
Posted on Jun 23, 2010
Testimonial: "XOXOXO!!! You had the solution. Thank you so very much. Someone the repeat button was selected, just as you suggested. I can enjoy my CD again. "
The CD will not advance to the next track. One track is played and then it stops and waits until I program it to play the next track.
try when u turn it on. check all your bottons 2 make sure they r not stuck and than put a cd n and check 2 c if it will read the hole disc. or push play with a cd in there an try 2 skip songs 2 play
May 10, 2011 | Audio Players & Recorders
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Automatically advancing to next track while recording
Reset the machine.
Record a cd with no imput.
It worked like a charm.
Oct 06, 2009 | Tascam CD-RW750 CD Recorder
The cd plays first 2 tracks only and shuts on 3rd
There may be foreign material on the sled motor and or the sled shaft keeping the steping motor from advancing to next track. Especially if it does this on all CD's you try. You will have to have the unit cleaned and also the stepping motor could have a chiped gear on it, the only reasonable way to solve this problem is to have the laser assembly replaced.
Oct 03, 2009 | Aiwa CSD-TD49 Cassette/CD Boombox
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Sharp CD-DP2400 3-disc mini component system stops playing in first track
the rails on the laser slead need cleaned..the grease gets hard/dirty and stops it from moving skip it to track 16 to move the dirt off the track..
Oct 26, 2008 | Audio Players & Recorders
CD player skips on early tracks
The lens assembly in a CD player glides along on a two rail track, kinda like a railroad track except tubular. The lens carriage is moved over this track by a small motor driving a worm gear. (Think long, tubular and spiral). If the rail tracks or the worm gear dry up or have dust accumulating on them, this could be the cause. Normally they have a light gear oil or lithium grease on them to keep them lubricated.
Mar 08, 2008 | Audio Players & Recorders
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
Sony MEX-BT2500 CD Player Logo
213 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
