Question about Sony Cyber-shot DSC-S600 Digital Camera
Access Screen Each time I attempt to turn on my camera, I get a black screen that says "Access" and the camera powers off. I've tried removing the batteries for a few hours, and reseting the camera to factory specs, but so far nothing has worked for me. Any tips?
    Novelist:
  • 198 Answers
Hello, When the camera shows this it tries to acces the lens mechanism, in terms of extending the lens and/or powering on the ccd sensor. Failure in doing so will result in an error code or simply by having the camera not showing anything else at all. Therefore the camera has a problem with the lens assembly. It's the most common problems with digital cameras. However this can only be solved in a service center because dissasembling the camera yourself will risk lens assembly damage, as they are very delicate equipment. I suggest you go to a service center, not the larger ones working for corporations, instead a smaller generic one. Ask them a price estimation before they actually repair it. Repairs may varry from a simple lens readjustment to the replacing of the whole lens assembly, this can get expensive on sony models. Please reply if you have further questions. Good luck with the fix and sorry for not being able to assist you with a quick fix.
Posted on Apr 26, 2007
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Turning on the camera.
You can try to remove the battery to allow the circuitry to reset to factory defaults. If that do not work, I would suggest to get repair under manufacturers warranty. Most electronics devices have one year warranty.
Good Luck.
May 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a...
I have a cybershot DSC W55. When the power button is switched on the lens extends and the "access" message shown on screen. Also amber light is flashing above screen. After a few seconds I get a message to power on and off again. I\'ve tried switching on and off a few times, removing battery pack and memory card, but nothing seems to be solving the problem.
Feb 19, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Samsung Notebook NP-N130 turns On but would not boot up with a blank screen. I had already remove the battery and attempt to turn it On but still the same problem. Please help Thanks
1. Try to check if the AC adapter is working.
Check the LED indicator
2. You might need to replace to laptop motherboard
power supply is defective
Thanks. Cheers!
Apr 19, 2010 | Computers & Internet
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
My Sony DSC-w55 turns on and reads on ACCESS on black screen.
try to remove the battery for a few minutes this should refresh its system once you power it up again.
Aug 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony DSC-W30 ACCESS problem
try hitting it against something harder (like a table). I just did and it worked for me.
Jan 28, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
I had the same "access" problem as everyone else - but here's the real way to permanently fix this problem when banging and smacking it barely works.
1 - Remove battery and memory stick. Back up the mem stick if necessary or paranoid.
2 - Using a small Phillips head screwdriver, remove all of the screws you see from the front (lens side), right and left sides of the camera. Then remove all three of the covers and place aside.
3 - Clean and remove all dirt & dust in and around front of camera, paying special attention to areas close the lens and lens housing areas.
4 - Insert battery and close the battery cover and then PLACE THE CAMERA RIGHT-SIDE UP ON A FLAT, NON-METALLIC SURFACE, MAKING SURE THAT YOU'RE NOT TOUCHING ANY OF THE EXPOSED CIRCUITS OR WIRING TO AVOID POTENTIAL SHOCK. This isn't a danger issue, more of a cover-my-*** related note. When I did this for my DSC-W55 I touched it just about everywhere without receiving generating anything close to a shock.
5 - Press the power button. If lens does open fully and you're still receiving the "access" message, continue powering off and on while using a toothpick or compressed air to remove remaining dirt and dust particles.
6 - When you're DSC-W55 is back in business - and after you've tested it multiple times via several on/off cycles, begin replacing the covers one at a time. The trick is to replace one cover, then to test the camera again via several on/off cycles. Do this until you've reattached all covers and camera is fully operational once again.
Tip - you may find success early by varying the tightness of the screws for each side's cover as you move along the on/off cycle process.
Dec 22, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
