Question about Powercom (BNT-1500AP) UPS System
Powercom BNT 1500AP quit working after power outage
After a short power outage (20--30 sec.) the UPS was out and would not restart. Additionally, the circuit breaker on a power strip plugged into the UPS output was tripped. I suspect there was a surge. Is there a replaceable surge module in this unit? If so, how do you get at it?
  • copernicusdr Dec 31, 2008
    You were right, wwright. The battery voltage tested low, and after removing the cells, I saw that the cases of both batteries were ruptured (no serious leakage). The 40 Amp fuses (slow-blow, from the looks of them) on the circuit board were fine. $50 for two new cells with more Amp-hours, some screwdriver work, and the problem was solved. This is the second time I have replaced ruptured SLA batteries in a UPS unit.
    Anybody out there g
    Anybody out there got a hack for using standard automotive batteries with a UPS unit? Much more Amp-hours and probably more reliability at the cost of venting the batteries and keeping them upright.
    Problem Solver:
  • 14 Answers
From your description it appears one or more batteries are bad..The circuit breaker on the Power Strip..which more then likely is a 15 Amp..tripped due to over current conditions..check the batteries and reset the circuit breaker..That should take care of it
Posted on Dec 31, 2008
Hi, I have two of these UPS and in both the cooling fan makes a lot of noise, is that normal, or how I can do it to stop that noise. Thanks
try removing the fans and remove a sticker at the centre, to find bearings,clean them with a cloth then spray Iso-Propyl alcohol (IP) clean with dry cloth put few drops of low viscosity oil(2T oil will help).tell me if the noise do reduce.
Sep 29, 2013 | Powercom (BNT-1500AP) UPS System
Beep beep and shutdown ups
most probably check on your bateries.
Aug 13, 2013 | Powercom (BNT-1500AP) UPS System
AC trips circuit breaker not long after a recent power outage.
Sounds like your compressor is shorted to ground. If you are able, unhook compressor, wrap wires and restart. If breaker doesn't trip than u know.
Jun 07, 2017 | DeLonghi Heating & Cooling
My Cyberpower 550VA keeps turning off. I can turn it on, and it will stay on for maybe 2 seconds, and then it turns off again. Any solution?
your ups cannot get enough power from the outletreplace the battery of your ups 12volt 7ampere reset the small breaker. when it still turning off test the continuity of the small breaker and the cord to plug use a multitester.
Aug 25, 2011 | CyberPower 550VA 330W UPS Green S System
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
Computer restarts as soon as power goes off, its not an ups . When i manually turn off the power to the UPS, it switches / relay works fine, but if actually if there is a power outage the relay does not...
Your question is slightly confusing. Do you mean that the computer is not powered by a UPS? If the computer is not connected to the UPS, then why have a UPS? If the computer is not connected to the UPS and restarts when you turn the UPS On, your circuit feeding the UPS is overloaded and the voltage dips. If the computer is connected to the UPS, and restarts when there is a power outage, the fault may lie in the reaction of the HP 800. This unit looks to be a line interactive unit and it is not a true on-line UPS. The line interactive and battery backup (no voltage regulation) units both should have a switch to battery power time of 4 msecs, or less. If this unit is faulty and the switchover time is longer, it will not continue to hold up the computer internal power supply. If you are trying to run a laser printer on the HP unit, it won't have enough output capacity.
Feb 20, 2011 | HP Computers & Internet
My ups is switching on on battery for few seconds but without AC output, the same thing when I put AC power it switches on normally but also without AC output.What can I Do? Please help
does it have a led display for battery charge? if it is very low battery is bad,when you add a/c no output because bad battery will not provide a/c in power failure
Feb 02, 2011 | Powercom (BNT-1500AP) UPS System
My powercom ups canot power on
hi there check the fuse and let me know the condition of that.
Jan 19, 2011 | Powercom BNT-600AP (bnt600ap) UPS System
Hi! Per our UPS problem is when open 3 or 4 hours, then auto Off the UPS. please let me know what the problem. And i need to change the PCB board or just repair the PCB board? Thanks Regards
If you unplug the unit and it powers your PC for 3 or 4 hours then turns off, it is because the batteries are empty and this is normal. If it is plugged-in with power and shuts itself off after a few hours, then the battery cells may be in need of replacing. You can purcase an inexpensive replacement battery here: http://www.upsforless.com/browseproducts/Powercom-Replacement-Battery-Kit-BNT-500A-BNT-500AP-BNT-600AP-BNT-800AP-KIN-425CSU-KIN-625CS.HTML
Dec 01, 2010 | Powercom BNT-600AP (bnt600ap) UPS System
Powercom (BNT-1500AP) UPS System Logo
390 people viewed this question
Top Powercom Computers & Internet Experts
David Payne
David Payne
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
