Question about Akai LCT3215/26 32 in. LCD Television
Dvd connection I have a 32 in hd akai lcd, i lost the manual. i'm trying to connect a dvd player but the movie comes through in a gray picture. what am i doing wrong?
    Genius:
  • 1,074 Answers
Probably either the tv or the DVD are in the PAL system check if they are, if yes then change to NTSC.if that does not work then you check your connections.if not you will have to call in a tech to look at your set.good luck.
Posted on Apr 26, 2007
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
AKAI LCD TV/DVD Player Combo connect to Motorola DVR Cable Terminal
Please follow guidelines given in operation manuals of both.
Aug 02, 2012 | Akai LCT2701AD Television
Would like a manual for a transonic 32' hd lcd tv thanks
DVD player from anotherr country - won't work.
Jun 07, 2012 | Televison & Video
I have a Panasoniv 32 inch vivera lcd tv. When I watch a movie the picture looks grainy. Kind of like the pixels are not forming to complete the picture. Am I missing a cable or some kind of compnent for...
If you're watching the movie from a DVD player, make sure all of the cables are fully plugged in and connected. If you're watching the movie from a VHS, it will probably continue to look like that.
Feb 28, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Need wiring diagram for DVD PLAYER ASSY DL-06LS-M1
i'm trying to hook up a dvd player to my lcd tv.i can play a movie through the tv but i cant record tv on to the dvd player.i only have antenna tv can you please solve this problem for me.
Jan 15, 2010 | Akai LCT3201TD 32 in. LCD Television
Tv will not come back on,inserted a DVD and tv went blank, no sound, no picture
prob your choice of dvd movie, tv's pouting right now, just a temp prob, will turn its self on when finished with tantrum
Nov 26, 2009 | Akai LCT3201TD 32 in. LCD Television
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
Dec 12, 2008 | RCA F25441 25" TV
How do i get the movie out of the dvd player
I have the same problem. How do you get a answer from Tech support
Jul 31, 2008 | Akai LCT3201TD 32 in. LCD Television
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
59 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
