Question about Canon CanoScan LiDE 70 Flatbed Scanner
Compatibility question Is Canon CanoScan LiDE 70 Scanner compatible with window vista? Seems like it is not working with my PC which has Vista 32 bits.
  • twi_institut Dec 29, 2008
    short but direct to the point. Greatly appreciated!
    President:
  • 1,179 Answers
You need to download the Windows Vista driver from the Canon website. Hope this helps & please remember to rate my answer.
Posted on Dec 28, 2008
Canon Canoscan LiDE 25 shows "USB device not recognized" on Vista Home Premium 32-bit
Point # 1 : Electronic devices are not made to be used sparingly or stored for long periods of time.
Point # 2 : 5-6 years is not 'barely' in-terms of an electronic device's lifetime (Given that the warranty for your device is about 1 year !).
Point # 3 : You obviously tried almost everything on the computer site of this issue, Its time to take your device to a service center.
Dec 03, 2013 | Canon CanoScan LiDE 25 Flatbed Scanner
There is no Windows 7 driver for my lide30 scanner.
Visit http://software.canon-europe.com/products/0000466.asp to download the Windows Vista drivers for the Canon CanoScan LiDE 30.You can try installing these using compatibility mode by right clicking on the downloaded files, and selecting 'troubleshoot compatibility' - select the option for 'worked in a previous version of windows' and then select vista
If this does not work, you should extract all of the downloaded files, press start, right click on 'my computer' select 'properties' and then click device manager. Right click on your unknown device and click 'update driver software' and then choose your extracted files to scan for the driver
Feb 25, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
Driver for canoscan lide 35 for windows 7, 64 bits
this is the support site ...and the driver I found there is for windows 7 but on 32..Cause they do not have one for 64 bits OS yu should download and try the Vista one on 64 ..cause the compatibility is usually high and it s worth give it a try ..If not the only way you will be able to use is if you reinstall the windows & on 32..You will not feel much difference but the driver's compatibilities will be easier to match
May 31, 2010 | Canon CanoScan LiDE 35 Flatbed Scanner
Is canonscan LiDE20/30 compatible with wndows 7
Here is the link for downloading the drivers for canoscan lide 20 for windows 7 (compatible with XP, Vista e.t.c).
Canoscan lide 30 does not support windows 7, here are the drivers for Vista.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 25, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
I have canoscanlide 30 i canot install the toolbox to my pc windown vista whay can i do
two possibilities...
1. the toolbox software may need to be installed as administrator and in compatibility mode
2. it may not be installable if your pc is a 64 bit pc and your toolbox software is 32 bit... this is a common issue...
Dec 23, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Software for Canon LiDE 20 scanner (Vista compatible)
did you install the drivers? they were probably downloaded compressed- you need to look at your download list and install from there. don't know if vista refers to it as install wizard, as xp does, but check that the download was actually opened and installed. otherwise, it's sitting on your hdd doing nothing useful. i'm not familiar with vista, know a lot of people who tried it and switched back to xp. still waiting for the user reports for w7. supposed to be a great improvement on vista! so we wait and watch!
anyway, check out whether your patch for your scanner actually was installed!
good luck!
Sep 29, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
CanoScan N1220U
It will with the program from the link below.
http://windows-vista-updates.blogspot.com/2007/05/canon-scanner-drivers-for-windows-vista.html
Jul 12, 2008 | Canon CanoScan N1220U Flatbed Scanner
Scanning
This is all due to driver compatibility issue,please thry this,first remove all software n drivers for the scanner ,download driver from this site by selecting ur operating system,n install,do remember to reboot ur laptop after removing previous software.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=14003
do revert
thnx N
Jan 26, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon Canoscan LIDE 50
Hi am gonna provide you with the link from where you can download it, keep it mind that if you have changed operating systems, then the scanner might not be compatible with you current operating system. For instance if you had Windows ME or Windows XP but currently have Windows Vista there might be some compatibility issues. Good Luck! http://drivers.softpedia.com/progDownload/Canon-CanoScan-LiDE-Download-816.html
Jan 19, 2008 | Canon CanoScan LIDE50 Flatbed Scanner
Compatability of Canoscan LiDE20/30 with Vista pc
Yes the software should certainly work with windows vista. The same is also available on the canon support website if you wish to download it.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
I have provided the link as well.
Hope this helps
Sammy
Nov 30, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
94 people viewed this question
old marine
old marine
