Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
My whirlpool thin twin filled with water and stopped!:(
It just filled with water and stopped a few weeks ago. We had to drain it manual. My dry also, stopped drying my clothes. It spins but has no heat. I don't think the two are related. Please someone tell me its fixable.:)
  • Whirlpool Master
  • 8,220 Answers
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
Posted on Jan 01, 2009
Why doesn't my whirlpool thin twin fill up with enough water to was a large load?
No cannot over ride set at large doe the machine fill to a certain level then stop if so operating correctly if it never stops filling with water then there is a leak in the fill system either a hole in pressure switch hose it popped off tub or water leaking out thru drain system pump or siphoning thru hose again if unit starts to agitate there is enough water in unit per design
Aug 21, 2014 | Whirlpool Thin Twin Washer and Electric...
Whirlpool Thin Twin randomly skips agitation during the cycle.
Did you ever figure this out? Mine agitates but instead doesn't start spinning and draining unless I open the lid. It then "clicks" and starts but it is strange that I have to do this to get it to spin.
Dec 20, 2012 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool thin twin filled with water then stopped!
Not sure about the dryer but there are a couple things that could cause the no draining issue.
You could have a leak or block in your pressure hose. Basically there is a thin, clear tube inside the cabin that attaches to the tub on the lower right side. If this has a leak or is clogged then the washer has problems filling and draining.
The other possible problem is a broken lid switch. This is an easy fix. Basically, the mechanical mechanism that goes down when you close the lid does not work properly so when it comes time to drain, the washer actually thinks the lid is open.
For both of these you would need to open cabin. I posted instructions for that here:
http://www.fixya.com/support/t1885690-whirpool_twin_washer_dryer_lte5243dq3
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing machine won't drain
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
LTE6234 Whirlpool Twin Thin Timer Broken?
Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
560 people viewed this question
Dan Webster
Dan Webster
Sal De
