Question about Samsung ML 2010 Laser Printer
Can't print from a Visual Fox Pro application with raw printer processor
Hi, I need to print from a Visual Fox system to a shared Samsung ML-2010 printer. By default in the printer configuration the printer processor is RAW, but the printer blinks (like receiving data) and doesn't start any printing. If I change the printer processor to TEXT the printer does print but it doesn't recognize the especial characters like line feed, carriage return, etc. The same system works fine with HP printers with RAW printer processor, I don't know why it doesn't work with this Samsung printer. I've installed the latest driver from the vendor but it remains the same.
    Sergeant:
  • Samsung Expert
  • 406 Answers
The Report sent to printer should be in a recognised fonts and formats. If It work on other applications like word excel then you need to solve this through ur programmer of Visual foxpro reports.
Best Regsrd
Rafique
Posted on Feb 09, 2008
How can i print from my mac pro to printer samsung 2010
You can enable mDNS in your admin page and connect the mac and printer in same network and then you can setup the printer in mac from settings -> printers.
Jan 10, 2015 | Samsung ML 2010 Laser Printer
Samsung ml 2010 firmware update, samsung ml 2010 not responding when paper end
Dear
you need not update firmware for this model. Pl. do the printer status monitor(SMART PANEL). Down load from samsung site and run inpc application. when print command given it will display the problem.
Thanks.
Dec 31, 2014 | Samsung Office Equipment & Supplies
ML 2010 Laser Printer: have aquired a samsung ml-2010, have installed dri...
have you tried replace a new toner. If new toner also giving out noise. it is most likely the main drive issue.
May 17, 2010 | Samsung ML 2010 Laser Printer
Samsung ml 2010 in when start print tow led blinking
Hi
Think you may need to be a little clearer with your question to get any sensible answer. If you ar referring to the toner light flashing then you simply need to buy a new toner and replace it.
Taz
Oct 23, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 can't print in a certain format
you change office 2003 or its problem page setup
Aug 09, 2009 | Samsung ML 2010 Laser Printer
Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Jun 22, 2008 | Samsung ML 2010 Laser Printer
Maybe you can help me with my printer error
I'm not familiar with your Visual Fox system, but from your description it sounds like you are exceeding the printer's memory. Your model only has 8MB RAM and is NOT expandable. Even if your document is less than 8MB, the printer has a lot of overhead it has to deal with. Some printers make better use of memory than others. Your HP printers probably have more memory and/or a better scheme for handling it. You might want to try a VERY small document to see if it prints. I know this doesn't FIX your problem, but hopefully it will help solve the mystery. Ed
May 24, 2007 | Samsung ML 2010 Laser Printer
Problem with printer
I wonder if you could somehow add the printer codes (linefeed, carriage return etc.) into the printed document manually. If you have looked at some of the manuals which came with old printers (like Radio Shack or Epson dot matrix units), they had a listing of special ASCII codes which would produce a linefeed, or a special character. Though I never tried it, one could insert one of these ASCII codes, and the printer would, I guess, follow that coded instruction. Experimentation would be required, but maybe you could get things working more to your satisfaction. Does your printer have the option of using Postscript? Again, this isn't an area of expertise, but some printers have such an option. Does your Samsung have PCL like language, or by chance emulation (HP compatible) options?
Printing dbase reports on a samsung laser printer
dBase as in the old DOS based database program from the late 80s - early 90s? If so we'll need some more details on which version (II, III or IV)and the Operating system the program is running in to start with.
Feb 17, 2007 | Samsung ML 2010 Laser Printer
Can I print in Dos Programme with USB Printer
Assuming the printer can understand DOS coded printouts (which most should be able to), you can do it like this: Go to Control Panel | Printers | ML 2010 and share the printer. Then go to a command prompt Start | Run | type cmd Assuming that you share it with the share name "MYPRINTER" and the computer is called "MYCOMPUTER", then type NET USE LPT2: \\MYCOMPUTER\MYPRINTER /PERSISTENT:YES at a command prompt. Now you can print to LPT2: and the output will go to the USB-connected printer. To find your computer name, right click on the My Computer icon (either on your desktop or the start menu) and choose properties. The window that opens will have a Computer Name tab.
Mar 22, 2006 | Samsung ML 2010 Laser Printer
Samsung ML 2010 Laser Printer Logo
160 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
