Question about Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood
Kitchen and bathroom faucets do not get hot,hot.Lukewarm at best.
If you turn on the kitchen sink and bathroom partially it will heat up enough to do dishes,etc. Water valve was rebuilt a month ago and the electronic control box was replaced 6 monthes ago.Box was replaced because pilot light would not light because gas valve did not open because box was not controlling it. problem started at pr about the same time.
  • 68 Answers
Ok the way it works man is the box aka power vent the gas valve wont open until the power vent is open u can manualy open the powervent witch will open the gas valve to turn on the piolt light and in about 30 sec the main burner will kick on now if the powervent is opening the the pilot light isnt lighting then u need to replace the thurmole cuple witch sences the pilot light is on if it doesnt see the pilot the it shuts the gas valve off so it doesnt fill ur house with gas
Posted on Jan 25, 2009
How do i turn off hot water supply from this boiler, need to change bath hot tap valve
You turn off the mains water valve (usually under kitchen sink) so no more water enters the property. Then you run all the taps to drain the system. When you've finished just turn the mains back on. Or if you have a modern bathroom most water inlets / pipes to the taps have their own isolator value so you just need to turn that off.
Nov 23, 2017 | Water Water Heaters
No hot water from kitchen tap
The hot side of the faucet is most likely plugged with something that came up thru the water system. The average thankless waterheater requires at least 1/2 to 3/4 gpm flow rate for the unit to sense flow and turn on. If there is not enough flow it will not fire and heat the water. Not sure about this particular unit but a few require at least one full gallon per minute flow. So chances are that if you fix the faucet, you fix the hot water issue at the same time
Jan 09, 2014 | Rinnai Water Heaters
Richmond water heater
The water inlet to the heater must be plugged.
May 16, 2017 | Water Heaters
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
Getting really hot water to the kitchen but only tepid hot water into the bathroom and ensuite. Do not need to put on the cold tap at all in the bathrooms but you can't hold your hand under the tap in...
If some taps have really hot and others luke warm, then you might have defective mixing valve, check valve, or crossover on single handled faucet.
http://waterheatertimer.org/Crossover.html
Crossover can also cause stacking event. Stacking could be part of puzzle.
http://waterheatertimer.org/Stacking.html
Once crossover or check valve or mixing valve problem is solved, if you have really hot water to some taps, then turn down thermostat to avoid scalding.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Add a comment for more help.
Jun 13, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
Tankless water heater not meeting the need
Yes the faucet could be a problem. Try changing for one which you know is ok.
The long run of pipework - each bend, elbow or joint all have a reducing effect on the flow, maybe enough to matter with a restricted outlet. none of this can be altered except by renewing with larger bore pipe - expensive!
Also there should be a dirt filter in the mains water input line/pipe. Try removing & cleaning. Try also removing , reconnecting and then the hot tap [faucet]
The boiler will have an actuator valve which fires it up when a certain flow of water is reached. If the flow is reduced AND the valve is worn, maybe a replacement. Not sure about it's USA construction but in the UK [it's called a diverter valve] many have a rubber diaphragm which is cheap to replace
Check also if it uses a flow sensor switch
Had a look at the Takagi web site and there are pdf's of manuals
takagi.com
Overall I am still thinking that the main prob is in the flow.
Hope I've helped - come back anytime
Rod.Davies
Feb 19, 2010 | RTO Takagi Jr. TK-JR-N Tankless Water...
Morco F 11E tankless water heater Slight problem
One more thing ,they do make a valve call mixing valve.That's to mix the water hot,cold to a temp. you want.Most restranrest have them in the water lines at the restroom.They suspose to keep it around 110 deg.
Mar 18, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Bosch AquaStar 125FXKIT-NG 125FX Natural Gas Tankless Water Heater w/ Hood Logo
220 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
